It means 'Dirty Filter' once cleaned you must press and hold down the 'On' button for 5 seconds and the message will remove.
This post has been helpful to me. Just to add some comment that may help others as well. The Trouble Shooting page says Alarm Signal "Fi" notice not F1 but it says ... The filter is dirty... But on page 13 The Electrical System Diagram says F1 relates to Compressor thermal cut-out which sounds like a big elecrical faulty. Actually both are related. I do not know if "Fi" in page 15 of Manual means "F1" , a typo error? A potential buyer pointed the difference, This post helped me to fix the error mssage after cleaning the filter. ie. Press and hold dwon "on" button for 5 sec. Cheers.
Thank you this was most helpful.
Yep - BINGO!!! Thank you
thanks a lot Mick
Thankyou for that info Mick
Helped my problem which was the F1 flashing
Cheers
thank you it was sending me batty also..no mention of that in the manual KUDOS and merry xmas
Mick your a legend, thanks for the help and information.
My PIU Cube 16 Olimpia Splendid portable air conditioner is displaying an error message 8, can anyone solve what this means? Thanks
We had the same problem, but with the Piu12 portable. Cleaned the filter, and tried to hold the on/off button on the remote. No go. Use the on/off button on the actual machine. Ours beeped when we pushed the button, and beeped again after we held it. Then restarted and the f1 error message disappeared. Yay!
No having same prob
Thanks alot to Bec Needham for your help on how to fix the F1 display problem! I was going berserk trying the other solutions that didn't work but yours did! Thanks again you saved me!
Thanks Mick. I'd cleaned the filter and machine was still showing F1 but after following your instructions all Ok. Thx heaps
