Kenmore Washing Machine 110.47512601
WIll turn itself on and off. If you unplug it, and then plug it back in. It will power up without pushing the power 'on' button, but you can sometimes make selections, but you can not start it or turn it off using the power button. It will turn itself off later on, but turn itself back on. Where can I get troubleshooting information and a parts list?
Sears has been out twice to try a fix and replaced, what the tech called a power control module. He had no test equipment and 'lost' wouldn't even start to describe the total lack of troubleshooting skills. They now think it is the front control panel.
What do you think it is?
  • 5,911 Answers
It could very well be the control panel. Of course, this would be a pure guess on my part, because I do not have access to your washer. It sounds like you have some buttons sticking on the panel that may be causing the erratic operation and display. You can view the control panel at Just type in your model number (as you have provided) and look at the various links on the following page. There are very good parts illustrations to assist you in locating parts. I hope this helps you.
PS There should be a tech sheet located inside the washer behind the lower panel under the door, or along the interior cabinet walls. This tech sheet provides some troubleshooting tips and diagrams to take test point readings.
Posted on Jul 29, 2008
Have a sears front loader its making a bad noise when it spins sounds like a air plane taking off its to years old model 110.47512601
Posted on Jan 03, 2009
Hello. I installed a new never used Kenmore washer today front load. As soon as we turned the water on at the back of the machine the water stated to enter the unit, Even when there was no power to the...
Not come across anything like it before, however, check your manual and see what it says about the position of the valve at the back of machine, if you've not already done so....otherwise goodluck.
Mar 05, 2015 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How do i change a lid switch on a kenmore top load washing mach
(For most)... Unplug machine at power (most important for any repair attempts).. Use a putty knife at about 2 inches from the front top corners where the top is attached to find the clips that hold the top to the rest of the machine. Once the clips are found, use the putty knife to push the the clips in while lifting the top up. The back of the top of the machine is held in place with clips that allow the top to be lifted far enough to set against wall behind machine without disturbing electronics. From this point, you should be able to see the switch and the manner in which it is clipped in. You will need your model number to order another. It is likely a Whirlpool or Frigidaire machine. Sears doesnt actually make anything. There may also be a part number on the part itself. Check eBay for replacement if you can wait for shipping.
Aug 05, 2014 | Kenmore Washing Machines
How do i reset my kenmore he 2 washer
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 03, 2010 | Kenmore HE2 Plus Front Load Washer
Water level won't fill past the lowest setting.
you may need to replace the level selector switch itself... if it has a reset option ( usually near the large side of the button, w/it plugged in, turn the switch all the way to reset, unplug the machine and then plug it back in. ) this has been known to work on occasion....hope this helps
Oct 18, 2009 | Kenmore Washing Machines
I have a Kenmore Elite Oasis HE Model 110.27072600. No mater what cycle, the machine would stop with 21 minutes remaining in the cycle. The only way to get it to resume was to unplug it, then replug it in...
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 09, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I have a Kenmore HE2 Plus front loading washing machine that is about 2 1/2 years old. It just started turning on and then off again, all by itself. Last night we ended up jut unplugging it. And when I...
Most likely it is the timer/control board.
It is a plug and play swap-out, but the tricky part is getting TO the board :D
Only you can determine if you have the skillset to attempt the repair - however without properly testing the components - you may just end up throwing $$ at the machine replacing good parts and still not find the problem.
This type of repair is best left to experienced repairmen. You will SAVE money in the long run.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 17, 2009 | Kenmore HE2 Plus Front Load Washer
Filled with water overnight
Hi When I plug it in is there any light on the panel that will come on without hooking it up the water lines???
Jul 11, 2008 | Kenmore Elite 45986 Front Load Washer
Power switch
It is quite possible. Replacement of the control board might be needed as well.
Jun 09, 2007 | Kenmore Oasis 27042 Top Load Washer
Washing Machines Logo
421 people viewed this question
Top Washing Machines Experts
