Thermostat not working - Heating & Cooling
  • Anonymous Jul 31, 2008
    model CW-1006FU thermostat is not working. I have removed front panel and vacuumed but it still does not work. Can I replace the thermostat myself?
Need more info
brand and model
some programables are powered by back-up batteries, some are not. t-stats like smoke detectors need there batteries replaced yearly.
Posted on Jul 28, 2008
My Quickstat has stopped working completely. not a gfi reset issue, but zero display. there is still power to unit. Im guessing that I need to replace unit.
Raychem QuickStat-TC Installation & Operation Manual
www.manualslib.com > Brands > Raychem Manuals > Thermostat
View and Download Raychem QuickStat-TC installation & operation manual online.QuickStat-TC Thermostat. QuickStat-TC Thermostat pdf manual download.
Raychem - QUICKSTAT-TC, Programmable, Thermostats ...
www.platt.com > ... > Floor Warming > Thermostats > Programmable
$144.29 - ‎In stock
Raychem QUICKSTAT-TC Programmable Thermostat Programmable Thermostat, 120/240V, 16A, GFCI, 4 Programmable Events per Day.Missing: tyco ‎working
Raychem Quickstat Floor Heating Thermostat Installation ...
Dec 26, 2015 | Raychem by Tyco QuickStat-TC Thermostat
How to wire six wire to three wire termenal
I'm pretty sure this thermostat uses digital communications with a dometic control board. In other words, there are no contacts in the digital thermostat to turn something on and off. Even if you ran a 12VDC wire to the thermostat for power, it won't work to replace a "real" thermostat. I bought one to replace my old analog thermostat and it's not going to work for me.
Oct 10, 2015 | Dometic 3313192.000 White Single Zone LCD...
A/C unit compressor stopped working after thermostat install - please help.
verify that the thermostat is completing the circuit on a call for cooling, check the contactor at the condensing unit, verify the low voltage, the wiring may be crossed somewhere.
Sep 29, 2014 | Heating & Cooling
Dpsr483ea1ww how to replace thermostat
  • Unplug the dryer's power cord from the wall connection. You will be working around the dryer's wiring, which can be dangerous if the power is connected.
  • 2
    Remove the rear cover of the dryer. Most dryers have four screws, one at each corner. Flathead screwdrivers will work for most models, but some require Phillips-head screwdrivers.
  • 3
    Locate the thermostat. The thermostat is circular or oval with a wire connection on each side. Remove the screws keeping the wires connected to the thermostat. Set them aside--you will be reusing them to install the new thermostat.
  • 4
    Disconnect the thermostat from the wires, then unscrew the thermostat from its mounting bracket. The thermostat will easily pull away from the wires once you have removed the screws. Discard the old thermostat.
  • 5
    Install the new thermostat on the mounting bracket. Be sure to tighten the screw enough to keep it secured. Connect the wiring to the thermostat and reinstall the screws to hold the wiring in place.
Jan 13, 2012 | GE Dryers
Have an 2003 Olds Alero 2.2L, overheating. Removed thermostat housing/feed pipe to check thermostat to find no thermostat present, however the heat has working, although it has took 5 or 6 minutes to warm...
I can't give you any specifics on how to change your water pump, but I can answer your questions about the thermostat. Yes, the heat will work withou a thermostat. And yes, a car will overheat without one, especially in the summer months. The purpose of a thermostat is to allow cooler water to flow into your block, but also to allow the water adequate time to be cooled in the radiator. Without the thermostat, water is continuously cycling through your coolant system, getting hotter and hotter. Often I see people with malfunctioning thermostats jsut remove them, sometimes on the side of the road, just to get where they're going.
May 02, 2011 | 2003 Oldsmobile Alero
Themostat is bad
If water heater thermostat is bad, buy a generic thermostat at hardware store and install it according to instructions shown on link below:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
I usually replace both upper and lower thermostats for about $28.
Lowes sells thermostats and elements.
If your water heater is a single-element/ single-thermostat, you can buy any thermostat with red reset button.
Technically a single-element thermostat has 1 less screw, but either thermostat will work.
If your water heater is 120V or 240V, the same thermostat will work of either voltage.
This is true because the thermostat is a simple bi-metal heat-reading device that does not operate on electric current.
That being said, you might want to test parts before replacing anything, in case problem is element.
To do comprehensive electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Image below shows generic thermostat with reset button. Each of these will work for single-element or dual-element tanks with either 120V or 240V. Wires connect just as they did on old thermostat. Tighten wires very tight. Press in reset button to make sure ECO is set. Put insulation and cover back over thermostat when finished.
Dec 22, 2010 | RELIANCE ELECTRIC WATER HEATER
I have a Rheem Gas Furnace with an old analog thermostat (Wires conneected to terminals R and 4 for the thermostat). I went to install a Rheem digital and programmable thermostat and it indicated that it...
if you have 2 wire at thermostat Terminals at furnace that the thermostat wire attach to should be R & W if your new thermostat has R & W terminals is should work, an easy thing to remember is the red wire on R the white wire on W. If 4 wire at thermostat at furnace green on G, Blue on Y, red on R,and white on W same at thermostat If these do not match find a thermostat with these terminals
Dec 06, 2009 | Heating & Cooling
Honeywell T882 Chronotherm Clock Thermostat needs replacement
The two wires from the transformer are to run the clock in the old thermostat. If you connect the two other wires to any heating thermostat, it will work. Don't forget to disconnect the transformer wires. Hope this helps
Nov 10, 2008 | Honeywell Electronic Programmable...
Blower not working with new thermostat
To get the fan to work, look at the heating system to see what termoinal the blue wire is connected to. It should be the "G" terminal. If so, connect the blue wire to the "G" terminal on the thermostat and then manualy switch the thermostat to "Fan On". Indicate what terminals you have on your new thermonsta ie "G" "R" "Y" "C" "W" etc... For a fan to work, typically you connect "R" to "G" on the furnace.
Nov 05, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
