Rinse aid and salt are not necessary if you use powder that is similar to the tablets. The lights are warning you that you havent added them, you know that so ignore the lights. If you live in a hard-water (limescale) area salt can be used as well as tablets or powder to make the water kinder to the machine, but most people just use tablets without rinse-aid or salt.
The little star means you've run out of rinse-aid. See the flap that's next to your tablet dispenser, it has the same star on the lid, inside there you can refill the rinse-aid by pouring it into the tiny gap next to the dial! The dial setting allows you to change the flow of rinse-aid...the light will then go off. However, I've yet to find out what the light with the two directional arrows means! Ill post when I know!
Phone Bosch 08448 928 979 for a step by step solution. Program select at 12 o'clock. Press ON/OFF and Time Delay button together. Press time delay button, display should change from 1 to 0, indicating warning light is inactive.
the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
It might seem silly, but you open the front load fully, so that's it's lying flat and then you pour the rinse aid over the holes in the near left hand corner (where you might otherwise think you have to open the trap door for the rinse). The rinse aid will flow quite neatly into the reservoir and hey presto, once it's full (you'll know it's full because it'll start to back up and overflow) you're back in business. No more annoying rinse aid light!
the cap doesn't come off, you just have to open the door all the way. then, when you pour the rinse aid into the dial area, it will get sucked into the dispenser. but if the door isn't open all the way it won't go anywhere and will overflow on you.
