Question about Dell W4200 42 in. HD-Ready Plasma Television
Screen issues :(
I need help, please!!!!!!!!!!!!! Have had the TV for @2 years.........I am thinking that because my housekeeper dusted it with or without a solution on the rag that it messed up the screen..........the TV turns on but it flashes and after a bit shuts off alone. Sound just fine though.......
HELP!!!!!!!!!!!!!!!!!!!!!!!!
Sounds like the Y-Buffer board, not the housekeeper sadly...
Most common part that goes bad...
Dell will charge you $1200 or so to just look at it...
Mine was 3 days out of warrenty.. Dell told me to go pound salt..
If you can find someone to look at it... Here's the part number that might be bad...
http://www.partstore.com/
Phone Number: 1-866-925-7278
PCB: LJ41-02760A - $84.36
And yes... Dell 42", Sanyo 42", Phillips 42" , and Samsung 42" Plasma's all use the same parts.
Posted on Sep 23, 2008
The two bottom lights are showing the two red ones water reservoir is full and leaking slightly out of the back of the machine i think water is not getting into the machine...happened right after i ran a...
I'm not sure what the problem is but when I contacted Tassimo they told me that the machine was defective and not fixable. They wouldn't do anything because the 1 year warranty had expired but they did suggest contacting Good Housekeeping magazine because they would possibly replace or refund any defective item they've given the "Good Housekeeping" seal within 2 years of purchase. However I wasn't covered by this because I didn't buy form and authorized dealer.
Feb 21, 2011 | Braun Tassimo Espresso Machine/Coffee...
Tv wont turn on, geen light flickjers but goes back to red and does ot turn on, i unplugged tv while it was on by accident.
The main board and or power supply is seeing a problem is shutting down the TV.
The cause for your issue could be the power supply, main board, and or the drive board(s) that drive the plasma screen. Sorry, but to trouble shoot that issue would require some TV tools and knowledge of electronics.
Perhaps the following can help you with a warranty repair.
1. If your TV was purchased from January 1 2008 to today---The TV does have a 1 year warranty on parts/ labor and a 2 year warranty on just the plasma screen.
2. If your TV was purchased before January 1 2008---The TV does have a 2 year warranty on parts/ labor and a 2 year warranty on just the plasma screen.
I hope this information has helped you.
Good Luck.
May 24, 2010 | LG 60PC1D 60 in. Plasma Television
Toshiba regza 32hl67 losing its' picture and motion is slow
I have a toshiba regza 32hl67 LCD tv which is only 2 1/2 years old. The picture on this unit just started to go the other day (screen darkens but images are still visible and the motion/movement is very slow). I contacted Toshiba and they just said to unplug the tv for 3 minutes to reset the tv. This doesnt work. I am VERY upset with Toshiba, after paying $800 for a tv that only lasted 2 1/2 years. If anyone has had similar issues and know how to fix it, please let me know. Thanks
Apr 26, 2010 | Televison & Video
Mitsubishi WD-62827---PICTURE TURNS GREEN
I had the same problem. I deducted that if my TV worked fine for an hour or so and then the colors became bad (green, people's faces purple...), it must be a overheating problem. Simple logic, right? So, I picked up a few tools and a small vaccum and went to work.
I went first for the main source of heat: The lamp. Just a few screws, and I removed it. The lamp cage has a fine screen to prevent the dust to cover the lamp. Mine was covered with dust! And the fan behind the lamp was also covered with dust! Bingo!!! That's my problem! I cleaned everything and vaccumed all the air vents on the the back of the TV. I put the lamp back and checked that the fan was working. The TV works like new since!
Before you are out of a TV for days and spend an arm and a leg for a "Technician" to fix it (replacing expensive parts that didn't need to be replaced in the first place), try what I described above first. It's very simple and it takes only 15 minutes.
Since my TV is 2 1/2 years old, I purchased a replacement lamp. I know that one of these days it will burn out. I'll be ready and my TV will be working again in 15 minutes!
Since my problem was solved, I didn't go to the next step. There must be one or two other cooling fans inside the TV, but they must be working...
Good luck,
alecoz@roadrunner.com
Oct 06, 2008 | Mitsubishi WD-62827 62" Television
Shadow on screen
your vertical ciruit is malfunctioning
May 26, 2008 | Protron PLTV-32 Television
IBM ThinkPAd feezing & screen not working
I have about 50 IMB Lenovo ThinkPad R40 at work, this "defect" comes if in use every day, from 1½ year to 2 years.
I have tried to fix it, but have to admit that I have found my superier.
Buy yourself a new one here for xmas.
Dec 27, 2007 | IBM ThinkPad R40 2722 Notebook
RCA DLP/HDTV Vertical Lines
This is djb1 who commented above on the vertical lines that have gotten progessively worse. I may have found a potential solution. I unplugged the TV, took the back door off where you replace the lamp, took the lamp out, changed our vacuum from a vacuum to a powerful blower and blew ALL visable dust off anywhere that I could. I paid special attention to the heavy dust that was on the TV blower fan blades and around the mirror. I also held the blower on the outside of the TV on the vents around the lamp door.
After I plugged the TV back in, the lines have disappeared. We watched TV last night for about 2 more hours and the vertical lines never came back. So far this morning, the lines have not come back and it has been a couple hours as well.
It's worth a try. The free solution may be as simple as clearing out all dust. LET'S HOPE IT'S A PERMANENT SOLUTION!!
Dec 19, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Scrolling through menu on it's own
I'm having the same exact problem. does anyone have suggestions? mine is going through the menu and other video ports without cause. mine is also about 2 years old and started doing it today. its always been in a dust free clean enviorment. please please please help.
Jan 15, 2007 | Toshiba 35A44 35" TV
Dell W4200 42 in. HD-Ready Plasma Television Logo
267 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
