Question about Hitachi 43GX10B 43" Rear Projection Television
Hitachi 43GX10B 43 in. Rear Projection TV has sound, but no picture
i have a Hitachi 43GX10B 43 in. Rear Projection TV and we have sound, but no picture. video2 is used for the Dish TV antenna and video1 is for dvd. we have sound, but no picture. i can go to local antenna and get a snowy screen and can see the menu and manipulate around the menu. switch back to video2 and still no picture.
any ideas?
    President:
  • 1,197 Answers
Is the Lamp ok? Go to the rear of the set and turn on the set with your remote while looking at the vent slats. If you can see a bright light through the vent slats then your Lamp is working. If the lamp is on and you have sound and no pix, then the Digital bd is in what we call "Video Mute" and will have to be replaced. Also make sure that the Lamp Door is installed and the screws are tight
also check to ensure the following.....
1. re-seating the DVI cable on both sides
2. Check to be sure the lamp door sensor is closing (that is not your issue but i thought i would post the complete answer)
3. Check colorwheel is spinning up (should be a low hum, and not sound like a fan)
*** it is very possible it is a failed colorwheel, but the set should go into shutdown, so it is probably not the issue.
4. If the set has sound but no picture replace DMD board....
If the set is working and then just stops working best bet is the DMD ( i would not replace just the dmd it is cheaper in most cases and much easier to replace the lightengine) but if the set just is not working and just failed and is now always not working best bet is the digital board.
If you have an osciloscope you can measure the video signal from the Digital board and see if it is present with the no picture, if it is then it is a bad DMD but if the video signal disappears of then you have a failed Digital board. You can not us a computer USB scope, they can not read most of the data from the digital board since they use multiple scan rates and wont trigger on them for some reason, a old school scope works best i have found, or one of those new LCD scopes that have an auto trigger work well i have found that it is all i use anymore.
you can find a service manual with schematics at a very cheap price at ebay......
regards
iversh
Posted on Aug 30, 2010
Blue shadow around picture. tried digital array blue won't converge. red and green work
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dul
Dec 02, 2010 | Hitachi 43GX10B 43" Rear Projection...
Hitachi 43F300 43 in. Rear hrojection TV
you possibly have a deflection or convergence fault.
Jul 27, 2008 | Hitachi 43F300 43" Rear Projection...
My tv sucks help me
Ryan, this sounds as if the green CRT has gone out in this set. You might want to double check the warranty of your television as this set might have a lifetime warranty on the CRT's. If you cannot find the warranty info on your set, call 1-800-448-2244 for further assistance
Nov 16, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Will not turn on/ black screen
My Hitachi Tv 43fwx20b turn on but not have sound and picture
Jul 03, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 43GX10B Convergence Trouble
try this site
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Aug 30, 2006 | Hitachi 43GX10B 43" Rear Projection...
Hitachi 43GX10B 43" Rear Projection Television Logo
128 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
