Question about IBM ThinkPad T40 2373 Notebook
My screen on my T40 shows lots of gibberish colored squares
When I turn on my T40 is starts and on my screen I get lots of gibberish colored squares. If I do press a couple of keys the colors chnage and I get different shapes ans forms on the screen. Any suggestion?
  • gamark Jul 29, 2008
    I find a very interesting article about my problem (http://www.thinkwiki.org/wiki/Problem_wi...) and I think you are correct it could be the graphic card.
    I will give it a go and try all the things you mentioned and also what is mentioned in the article above and I will post my fix.
    Genius:
  • 2,028 Answers
If you have access to an external monitor, connect it to the laptop. If everything works properly, then the screen or inverter has gone out. If you get the same garbled screen, then the video card has gone out.
Posted on Jul 29, 2008
Samsung monitor 204b screen image is split in to two parts; the upper part OK but lower part is gibberish, ghosty?
Interference. Separate the wiring so it doesn't touch. Touching wires create cross-talk of signals and keeps from running normal.
Feb 11, 2014 | Samsung Computers & Internet
At start up screen is black won't show anything
try connecting an external screen that way you will know if your screen is burnt out. if an external works then change the screen on your t40. good luck.
Jul 07, 2010 | IBM ThinkPad T40 2373 Notebook
When the screen is dark there are lines that run back and forth across the screen which is only noticable when pitcure is dark immage.
the screen bias needs to be turned down-ehind the front cover which is behind the grille there is a small black square about 3 inch square 6 little knobs sticking out 3 say in small letters screen and 3 say focus, don't adjust the focus just the screen for the coresponding color that shows up when picture is dark.best way to do this is darken the room and put it on video input with no signal if lines are white slowly
adjust 1 color after the other counterclockwise untill
lines disappear if only 1 color shows then only adjust the knob with the matching color. this is a very fine adjustment, to much will make your auto focus stop working. check it after you are done
Jun 20, 2010 | Sony KP-51HW40 51" Rear Projection...
When I power up my T42 thinkpad, the screen is covered in little red squares. Any idea what this is and what I can do to correct it?
This could be one of two things--a bad LCD screen or a driver problem,
Start the computer in safe mode. It should look OK, but not really great resolution. If the squares appear then, try an external monitor. Are the squares on that? If so, it's your video card which just might be part of the motherboard and must be replaced.
If the external monitor is OK, then it's your LCD screen
If the screen looks OK in safe mode (the LCD screen) then your video drivers need updating.
Jan 01, 2010 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
IBM think pad t40...the screen stays black. Shows
Are the activity lights blinking like the computer is doing something? If so the monitor may be disconnected from the unit or damaged. If so this is a pc repair issue, and a little tricky to do on your own.
Jul 03, 2009 | Battery Technology IBM ThinkPad T40, R50
Gibberish + won't finish loading Windows
remove the new memory first. if that does not help you may have some a virus, indicated by safe mode workng fine. One other thing i found would do that is a damaged Hard drive, not to likely here because safe mode works.
Apr 28, 2009 | Dell Dimension E521 PC Desktop
Prints Gibberish, not the Text - Epson Stylus 460
This is usually due to a corrupted driver. To fix this uninstall the printer using the Windows uninstall software facility on the Control Panel (I am presuming it's a Windows system, if not use the uninstall facility of your OS). Reboot the computer then re-install the printer. If you need more help with the uninstall/re-install processes, report back.
Feb 01, 2009 | Epson Stylus Color 460 InkJet Printer
Black box covers most of screen some channels, plus gibberish.
it is the closed captions on the tv. it is set to closed caption text. turn it off
Nov 24, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Lost my Contact List and recent calls
well one time {i had the same fone}  my contacts started to scroll uncontrollably, like as soon as i was in "contacts" it just started scrolling down so i wen't to the verizon store and it said i had water damage so maybe that could be the case? Take the battery out of your fone and look at the little square on the back. If it is any color but purple {most likely green} that means ur fone has had water damage and that you will need it to get replaced.
Jun 02, 2008 | Samsung SCH-a870 Cellular Phone
IBM ThinkPad T40 2373 Notebook Logo
286 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
