Question about Whirlpool GH7145XF Microwave Oven
Gh7145xf has lost all power.
Was useing the microwave and at the end of the cookink cycle the circuit breaker tripped and after reseting notice that the microwave had no power. that was two days ago and i have tested the outlat and it showing correct power. i have read your blog on the inline fuse and other possibilities, i am wondering if it is the fuse as i should be able to check once apart and if not any other possibilities. and where to get parts . any help thank you. srgracing@yahoo.com
  • Whirlpool Master
  • 9,098 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
Wont work or come on
Debbie,
If nothing is coming on with no lights or anything you probably have a blown fuse. Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 27, 2015 | Microwave Ovens
Used the microwave last night. Later I noticed no light display for the clock. Come to find out microwave lost all power. Model number smh9207st
If there are no fuses or circuit breakers, the unit could be down and out. Check you power box for any tripped breakers.
Dec 09, 2014 | In Microwave Ovens
Tripping circuit breaker
That unit shows that it takes 15 or 20 AMPS to run. What is the breaker amperage on the circuit where it is plugged in? Is the breaker a GFCI? You can tell by looking for the two buttons on the circuit breaker or the outlet.
Jul 18, 2017 | KitchenAid KCMS1555RSS Stainless Steel...
Samsung SMH9151 trips breaker when plugged in
You have a sort circuit inside, call a repairman or take to the repair shop
Aug 23, 2012 | Samsung SMH9151 Microwave Oven
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
Oct 21, 2010 | Microwave Ovens
Blowing main breaker
I have a hard time believing that the home's main breaker is tripping instead of the branch circuit breaker that feeds the microwave. I suspect it is really just a difference in terms. You should disconnect it and try using in another outlet - preferably one on a different circuit if possible. If the breaker continues to trip; this appliance should be disconnected and either be discarded, repaired or replaced before using again.
If the microwave works as expected (on a different circuit), it may indicate the original circuit is overloaded. Microwave overs are supposed to be installed on a dedicated circuit. This means only one outlet is on the circuit - no other loads (lights, appliances, etc.) are permitted on this circuit. A microwave typically requires 10 Amps or more when on "high" and will require a significant portion of the power supplied by a 15 or 20 amp circuit breaker. There is little unused to power much of anything else. If other appliances go out when the microwave trips the circuit breaker, you should contact an electrician to have a dedicated outlet installed for the microwave.
I hope this helps!
Sep 23, 2010 | Maytag Microwave Ovens
Microwave trips circuit breaker when plugged in repeats when breaker is reset . There is no problem with house electric.
The circuit is probably a 20Amp circuit (see the number stamped on the circuit breaker switch). Most likely, it is the same circuit as the refrigerator, crock pot, window A/C unit, etc....
Also, if you are using an extension cord or a power strip or a surge protector. Those may not have a high enough power rating.
One other possibility (not likely) is that the circuit breaker is a 15Amp and the microwave is 1500 watts.
What else is cut off when the circuit breaker is tripped?
Solution is to use a different outlet for the microwave, or turn off any other applicance in the same circuit (except the refrigerator, of course).
Hope this helps!
Sep 16, 2009 | Microwave Ovens
Microwave / Frigidare PLMV
Chek the high voltage capacitor and the diode . If one of them are short there is a chance for tripping the breaker
May 25, 2009 | Frigidaire PLMV168 Microwave Oven
GE Spacesaver microwave trips the circuit breaker
Since power = voltage X current, 1.58kW / 120VAC = 13.166A
So this unit should be fine on a 15A breaker unless the breaker is bad, the wiring or a connection is loose somewhere between the breaker and the microwave, or the microwave's magnetron or high voltage transformer are failing and drawing extra current.
Microwaves should really be on the own separate breaker if at all possible. Plus, the more a breaker trips, the more work out it gets.
Have you measured the voltage at the outlet? If that's off, current and power will be affected. It should be about 110-125VAC.
A good power test for outlet and wiring integrity is a toaster, toaster oven, or hair dryer rated at about 1500 watts.
If it doesn't run and heat steadily, then there may be a problem with the house wiring or breaker.
If it passes this test, the problem is likely in the microwave.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 09, 2008 | GE JVM1190 Microwave Oven
Whirlpool GH7145XF Microwave Oven Logo
71 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
