Question about Onkyo Audio Players & Recorders
Re: onkyo pre-amplifier (model P-3150V). Once powered on, unit will turn off and on until it stays off. This occurs maybe after 5-10 seconds after being powered on. I open the unit up and there is definately a burning smell after it's been powered for a few seconds. I love this unit and it has sentimental value. Any ideas? I'd rather repair this then purchase something newer. Thanks.
ONKYO PREAMP P3300 REMOTE SUBSTITUTE
Posted on May 16, 2009
  • Paulo Rosario
    Paulo Rosario May 16, 2009
    MY REMOTE ONKYO RC82S STOP TO WORK INEED AN UNIVERSAL SUBSTITUTE
Onyko tx nr616 receiver keeps shutting off. Only stays on for approximately 3 seconds. Can you help?
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 30, 2014 | Onkyo Tx-nr616 7.2 Thx Certified Network...
TX DS989 turns off after 3 seconds
Sorry but it does sound like an Amp failure and testing the unit for other electronic component failure will be needed
Jan 03, 2014 | Onkyo TX-DS989 Receiver
Onkyo TX-NR515 will not stay on
pls. check speaker wires for any open cracks. try the speakers to another amplifier and if it works from there your onkyo must be in trouble. open the unit and check for any blown fuse, if found any replace it w/ the same value, do not replace fuses w/ higher value.
Jun 30, 2013 | Audio Players & Recorders
What is the funtion of tape out, tel, pre amp out , power out, vox, alc... & what is aux dfrs???
Tape out and tape in are to connect the record and playback leads of a tape deck. Pre-amp out is to connect a Power Amp to the unit. The pre-amp will only take the signals from the various sources and amplify them, but only to a weak level. The main reason people would use this is to connect a more powerful amp to the unit.
The Power out could be either the mains power for a turntable or for connecting a pre-amp or maybe to another to amp.
Haven't got a clue to the others sorry!
Sep 04, 2010 | Bogen Communication GS100 Amplifier
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
Blow right speaker channel - ONKYO TX-SR506
There is some way to change a protection (fuse?). No. The fuse usually was not broken. How long did your amp turn on?
3 seconds (DC protect) OR immediately shut down (Over Current protect)? How to confirm?
1.Unplug the amp.
2.Remove the metal cover.
3.You will see a long vertically installed pre-amp board mounted next to those large power transistors fixed by 12 screws on a large aluminium heat sink.
4.Remove this long vertically installed board mounted by 2 screws.
5.With 2 screws removed, just pulling this board out and hold it with one hand.
6.Plug the amp and switch it on.
7.If your amp stays ON forever, the problem is from this long board.
8.If switch off at once, the problem is from power amp board.
Try the above- mentioned steps. I will tell you what to do next. Just search you tube for SR600 cap replacement. I have written an email here. Write an email to me if you want to fix this amp.
Sep 30, 2017 | Onkyo HT-SR800 System
P-301 onkyo pre-amp
Hi juicer, If you use the switched outlet, then everything will be turned on/off when you operate the preamp power switch. Use the unswitched, then you have to turn off each unit separately. You choose which one you want. It wont matter.
What connection do you intend to use to connect the LBT zx6 to the Onkyo preamp??
Mar 20, 2008 | Audio Players & Recorders
Nuvi 660 not locating satellites
Try this and see if it fixes your problem...first disable bluetooth then follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Dec 25, 2007 | Garmin 010-00358-00 GPS Receiver
624 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
