I don't have sound; unable to view videos; i have tried defrag; clean up; the message i get is; "file can't be played-system does not have required compressor-decompressor (codec) installed." also i have a "document viewer" popup with the message: the feature you are trying to use is on a cd rom or other removable disc not available, unsert document viewer....would re-installing my photoshop elements help any?
  • olga1027 Jul 28, 2008
    it was fine beforei started to defrag & delete programs; i tried to restore; no luck on the sound.
  • 68 Answers
Are your pc work properly before??
Posted on Jul 28, 2008
  • jude  ocon
    jude ocon Jul 28, 2008
    i think youve delete the driver of your soundcard..ryt?/
    try to install the driver of your soundcard..
Nokia 925 unable to view video file
I assume you are using default video player which is support a limited kind of video files. Try install "VLC for Windows Phone". You may can officially get it here https://www.microsoft.com/en-in/store/p/vlc-for-windows-phone/9wzdncrcv5tl .
Sep 27, 2017 | Nokia Cell Phones
Tip
How to defrag your hard drive in Windows XP 1. Open My Computer 2. Next right...
<span> How to defrag your hard drive in Windows XP<br /> <br /> 1. Open My Computer<br /> <br /> 2. Next right click and select Properties on the drive that you want Defragment.<br /> <br /> 3. Click on the Tools tab<br /> <br /> </span><img src="issken_16.PNG" /> <br /><span> 4. Click on the Defragment Now button<br /> <br /> 5. Select the drive you want to defrag if you computer has more than one drive and click on the Defragment button.<br /> <br /> </span><img src="issken_17.PNG" /> <br /><span> 6. When the Defragment complete you will get a message that states "Defragmentation is complete for:". At this point you can click ether on the on the View Report button or the Close button.<br /> <br /> </span><img src="issken_18.PNG" /> <br /><span> If you click on the on the Close button you will be taken back to the Disk Defragmenter Window. However if you click on the View Report button this will open of the Defragmentation Report. This report will show the stats on the drive after the defrag and any files that were not defragmented fully.<br /> <br /> </span><img src="issken_19.PNG" /> <br /><span> You can print the report or save it you a text file your future reference. After you are done with the report click on the Close button.<br /> <br /> 7. When done with Disk Defragmenter utility click on the "X" in the upper right to close the utility.<br /></span>
on Feb 10, 2011 | Computers & Internet
How to clean rootfs in nokia n900 ?
use purge for installed apps. And dpkg -l ' grep ^rc (this command will show you a list of apps configuration files still left in the system from uninstalled app)
dpkg --purge <appname> (This will remove it)
Performance Chip
May 22, 2012 | Nokia N900 Smartphone
ARE YOUR VCR(S) PRONE TO BE AFFECTED BY HEAT IN MY CELAR, FOR MY DISC ARE CLEAN AND THE MACHINE HAS BEEN "CYCLONE" CLEANED YET THE OPERATION OF THE VIEWING RATHER SKETCHY(ie. "check disc...
Moisture can build up on the lens of disc players that will cause choas with any disc. Celars are prone to damp and all electronics don't like that. If the Humid/damp problem is noticed by you then the video will suffer. The solution would be to do something about the air quality in the place. Such as a dehumidifer.
Aug 09, 2011 | Samsung SRV-960 VCR
The display screen shows " file error " only.
The manual can be viewed here:
http://www.fixya.com/support/p228383-toshiba_pdr_m4_digital_camera/manual-5928
I don't see anything about a file error message, though....
Have you tried using a different memory card, or formatting the one you have?
Jul 01, 2011 | Toshiba PDR-M4 Digital Camera
My acer aspire is taking too long to boot up..once its on,it works fine but the sounds are different,the start up sound...and when i play videos,they work fine but the sound lags and distorts
maybe because there are so too many start up programs try to disable if yor using windows seven you should be able to this by going to your start menu then all programs-accessories-run. when your in the run program type msconfig press ok then a menu will show up go to start ups then just un-check the start ups programs that you think is not important then re-boot your computer to apply this changes.
cleaning up your hard disk and defraging can also help to speed your boot up
to clean and defrag your hard disk go to your start up menu click my computer then right click on the drive that you want to defrag and clean do to properties then you should be able to see a circle telling how much space you have left in your drive right below it is a button "Disk Cleanup" just click it then it will show up the files that needs to be cleaned up.then just click the "clean up system files"button.
to defrag just click on "tools" menu there you should see a defragment now button just click it and it will defrag you hard disk.
adding some memory can also help to speed up your pc or laptop
about the sound problem re-installing your sound card driver should be able to solve the problem but if not then contact the store where you bought your laptop and let them test it so that they can repair it for free if the problem is in the hardware
Mar 17, 2011 | Computers & Internet
Unable to delete or print Microsoft Word document. Get the following message: "error processing command."
Please uninstall the printer software on your PC and do a full clean up of your system. Clean the registery, the temperory files, cookies, defragment and use an antivirus scan. Then reinstall the printer software and connect your printer to be detected and installed. Now try to print your document. I am sure it will work. there is a possible chance that some files got erased off on your system, hence you must always try to clean up and scan your PC in a time schedule. Hope this helps.Good day
Jul 06, 2010 | Office Equipment & Supplies
When I try to delete a corrupted save file on my Play Station 3 this message comes up "80010036 An error occured during the delete operation error." and I am unable to delete the file.
There was a problem when it first came out (not reading the hardrive correctly). Download a small demo or trailor and then delete all, this should work
If however it does not, then you will have to re-format the hardrive.
It sucks to be sony!
Jul 17, 2008 | Video Game Consoles & Games
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
