Question about Sony Playstation 3 (PS3) Console
Console will not work
I unhooked my console in my gameroom and hooked it up in the living room using a HDMI cable (it's hooked up by component cables in the gameroom). After playing last night, I took it out of the living room and hooked it back up in the gameroom. Now it doesn't work. No signal.
You should never unhook or hookup anything hot. shut your stuff down and then plug unplug whatever it is you are doing
good luck cullen
Posted on Jul 28, 2008
I tried to hook my wii to the new hd led flat screen but its black and white I tried doing the yello cable to green but it doesnt work and all the other inputs dont have ac jacks its just hdmi hookups
The yellow cable is RCA component and it sould not be connected to the Green port. Why not get a HDMi cable to make the hook up easier? Component RGB connection requires a RGB cable along with a stereo audio cable where as HDMI requires just one.
Jun 10, 2011 | Nintendo Wii Console
Hooked up hd cable to ps3 and tv, now have no sound
Be sure to check the cables. You may need to replace them.
Try the cables with another component, if possible.
Also, try using AV cables to verify that it is not the TV and to simply troubleshoot:
To get back to default AV settings:
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until it shuts off again.
Once you have verified that AV is working, turn off console, take out AV cables.
Plug in HDMI cable and turn system back on. Switch TV input to HDMI and it will ask you if you would like to use the HDMI cables, select yes again and verify.
If you cannot get sound, again, check the cables..
If new cables do not work, then your HDMI output is going bad, not from use rather normal wear and tear of the motherboard.
To get the best non HD picture, you will need to get some 'component' cables, rather than the standard AV (red, white, yellow).
Good luck
Jan 27, 2011 | Sony Playstation 3 (PS3) Console
I can not get my ps3 to work with the component cables. I had it hooked up in my other tv with a hdmi cable and it was working
there is no true HDMI cable for the Wii but a "Component" cable which is as near to HDMI as possible. The cable has 5 plugs on it (make sure your TV has the same 5 plugs). They are available off of ebay
better u download repair guide
click here to download repair guide
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
How to hook up a game console to an Olevia 232-T12
It all depends on your game console.
You can connect most to the Component, Composite, or HDMI inputs.
For modern consoles, use HDMI cables or provided Composite cables.
HDMI = Single cable and single plug (Best)
Component = Red, Green, Blue, Red, and White plugs (Average)
Composite = Yellow, Red, and White plugs (Worst, used for most older consoles and older TVs)
Nov 25, 2009 | Televison & Video
I just bought a PS3 slim and hooked it up to my 65'' Toshiba DLP TV using a HDMI cable. The problem is i have picture but no sound. I have tried the settings and all seems to be fine, also tried different...
not 100% sure but check the manual for your tv it may be that you need a faster hdmi cable, as with having a larger tv it will work at a faster rate so the basic hdmi cables wont work.
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
Ive had my PS3 hooked up using HDMI for years now but i bought a component cable because i have just bought a PVR and it can only record using component and not HDMI. The problem im getting is that when i...
Hook it up with the component cable and then hold the power button on the console until something comes up on screen. Make sure you have selected the component input on your tv or else you wont get anything anyway.
What holding the power button does is it resets the video settings to the lowest common denominator and then you can reconfigure it for the optimal picture quality of the component cables.
If that doesn't work double check the component connections on the back of the TV and just make sure they are where they should be and that no accidents were made while hooking it up.
Please post the results from these steps here so that I know what happened.
Jun 09, 2009 | Sony Playstation 3 (PS3) Console
PS3 will not display on TV
WHEN YOU START YOUR PS 3, KEEP YOUR FINGER ON THE START BUTTON UNTIL YOU EAR A SECOND BEEP ( BETWEEN 5 & 10 SECONDS); THIS WILL RESET AND SELECT THE RIGHT CONNECTION . I HAD TO FIND THIS PROBLEM WHEN WE WERE SWITCHING FROM THE LIVING ROOM TO MY KID'S ROOM.
LET ME KNOW, HAPPY NEW YEAR.
PIERRE ( MONTREAL)
Jan 01, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 hook up problem
I ended up using the component in cable hookup and fiber optic digital audio instead of HDMI - works fine.
Dec 28, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 Does not display on TV using HDMI or regular video
This happened to me a few years back so I apologize if it's not 100% accurate. If you can get it to work on another TV, go ahead and connect it to that, and go in to the settings to select the video input. If it's connected through an HDMI cable, then it will probably be set to HDMI. Change the input here to whatever cable you used in the living room. You will have to power it off at this stage, but when you connect to the other TV it should work.
Mar 14, 2017 | Sony Playstation 3 (PS3) Console
Audio but no video using hdmi on ps3
the cables might be faulty so borrow some one elses cables and try them if you have that option or just go back to the cables that came with it for now.
Jan 08, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
