Question about Mitsubishi WT-46805 46" Rear Projection Television
Mitsubishi WT-46805 46 in. Rear Projection Television- No Picture
I'm getting audio but no video-- Previously whenever text came onto the screen my lines were off-- Now I can't get any video but audio is ok
I had audio and no video. Now I cant get ant thing and the TV turns off by itself
Posted on Aug 24, 2008
Mitsubishi WT-36809 turns on for 2 seconds and then turns off. The error code is 22. Any ideas?
Verify the model number. Some of these Mits. family have bad picture tubes, and oil spills out onto the signal board. Look inside front panel, RHS tube, look below it onto signal board. If you see an oil puddle, then tv is toast!
Jan 18, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Tv has audio but no picture. tv was working perfectly fine last night with audio and pic but now no picture
kindly check ur video cable if ur r useing audio/video cables for you tv
if not u need to check for ur tv tube
Jun 04, 2010 | Mitsubishi WT-46807 46" Rear Projection...
I have a Mitsubishi WT-42311. Last week the
where you saw blue it sounds like your blue crt is shorting out could be just the video amp so
i would suggest you have a tech look at it for and estimate
Nov 24, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi problem
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
    Colors don't line up
    One or more colors can't be adjusted when using the convergence menu.
    Screen is bowed or warped.
    No Audio / No Video
You can see some examples and find a fix here...
Sep 25, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Not enough hd inputs for mitsubishi wt-46809
The splitter may work or an audio/video switch box like this one
May 03, 2009 | Mitsubishi WT-46809 46" Rear Projection...
WT 46809 Big Screen
Good Day y'all;
When the is picture being intermittent and bowing then the most common problem is that the convergence circuit has failed or is failing. If you don't get fixed, the will go DOA soon.
Good Luck, big IRISH.
May 03, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT 46805 ~ Picture gone..... :0(
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
111 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
