Question about GE 16.7 cu. ft. / 473 liter Upright Freezer FUF17DMRWH
Up right 14.7 cu GE freezer
Freezer has ice in bottom and drain was plugged possibly.
1. How do I unplug the drain hole now that I have all the ice gone in the freezer and my food in in coolers?
2. pluged the freezer back in the light comes on but the freezer doesnt restart. (yes the control is on 5)
  • 943 Answers
HI to clean the drain tube. pull fridge away from the wall .find the drain tube, by the drain tray. push a small plastic hose, up the drain tray. blow in the hose, to clear the debris. thanks the appliance doc.
Posted on Oct 15, 2008
Self defrosting / but there is ice in the bottom
The most common thing that causes this is a stopped up drain. Thaw the ice out of the bottom and locate the drain hole (probably towards the back, possibly behind the back panel) and clear with with a stiff wire or coat hanger.
If the water is unable to drain from the freezer during the defrost cycle it collects in the bottom and freezes there when the freezer is running again.
Hope this helps, let me know if you need further assistance.
Oct 06, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
We have a GE 20.3 cu. ft. upright frost free freezer that keeps forming a layer of ice on the bottom, which we assume is happening when it is defrosting. How do we unclog the drain?
I let the ice box thaw out and use a shop vac to open the drain hole. You can find the end of the drain hose above the compressor drain pan.
May 28, 2010 | Freezers
Amana Freezer DeepFreeze AFU2067BW 19.6 Cu. Ft. ice in bottom
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Feb 20, 2010 | Amana Freezer DeepFreeze AFU2067BW 19.6...
Water/Ice pooling in bottom of freezer
check out the drainage hole if it is properly closed.
Frost free freezer
Hi, It sounds like the defrost drain is plugged. UNPLUG the freezer. Remove the rear panel and you will be able to find the drain hole and remove the ice. Once you get the iceout of the drain. try and fluxh it with hot water (A baisting serigne works great). Sometines they plug up with duse from underneath. I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
Mar 05, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Water in the floor
there is a drain hose that comes out of the bottom of the cabinet into a drain pan underneath your freezer take a look and see if that got pulled loose during your move. if it is in place then you most likely have a plugged drain. this can be cleaned fromt he inside at the botom. reomve the bottom basket and the shelf right above it. you will see ice build up on the floor of the freezer and and behind the cover. just defrost the ice you will uncover the drain hole flush warm water thru the line till it runs clear. good luck peyton
Jan 30, 2009 | Frigidaire 16.7 cu. ft. / 473 liter...
Ice built up on bottom of freezer then dripping down front
Probably a clogged drain. Use a pipe cleaner to unclog, then a turkey baster with hot water to clean out anything else. Then when the drain is clear, pour a weak bleach solution down the drain to kill the mold that probably caused the blockage If possible remove all food and let it sit unplugged for a day or two. This will clear some defrost problems.
Jun 22, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
Frost Free Freezer
sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 04, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
GE 16.7 cu. ft. / 473 liter Upright Freezer FUF17DMRWH Logo
291 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
