Question about Pinnacle Studio Version 9 for PC
Pinnacle Studio 7 - Can't create MPEG file?!
Okay, so I'm running on this old Pinnacle studio 7. I have my movie saved as a project, with editing, effects, and music all in. I hit "create MPEG file" and it pops up with a little box, saying: "please insert the tape named "video1" and press ok when ready. If the timecode is not continuous throughout the tape, cue to the section including the frame displayed at the right. [There are several reasons why a tape might not have continuous timecode, including unrecorded areas or a manual reset]"
So I popped in the tape and pressed OK. It then searched through my video camera to find the section 'displayed on the right' (the first scene in my movie) it then re-captured everything on the camera, including outtakes and everything else, and published that into an MPEG file instead. Same thing happened when I tried to make it into a AVI file.
How can I convert my movie to a YouTube-accepted format without losing all of my editing/effects/music?
  • britindisgui Aug 11, 2008
    I tried it this morning on the card setting, and it worked! Thanks for the tip!
  • 2,794 Answers
Your output is set for tape. You have to change it to another device if your not sending to VCR. If you record to VCR, the Svideo or composite output to your video card is used while the audio goes through your sound card. Those cable ends are attached to a VCR. You can do the same with a DVD recorder if you have one. If your sending to to a DV tape, version 7 doesn't support it. Version 9 and higher do.
You Tube uses Windows Media files. Save the files in that format.
Posted on Aug 11, 2008
Pinnacle studio ultimate 12
Does the player you are using for playback support the file format you saved it in? If not you will need a codec to view it.
Sep 02, 2014 | Pinnacle Studio Version 12 for PC
Dazzle DVD recorder software does not save my video properly
You don't say where you are trying to save it to. Try saving it to the default location on you desktop hard drive and then transfer it to your phone.
Sep 15, 2012 | Pinnacle Dazzle DVD Recorder
I can't make a 16 minutes movie on my Pinnacle studio ultimate 12 program. I didn't have a problem to burn a 20 seconds MPEG file.
Hi and Welcome,
Click on the completed project in the timeline, go up to "Edit," click on "select all" in the dropdown menu, then RIGHT click anywhere in the now-highlighted project and select "Copy."
Now go back up to "file" and click on "New Project." Your current timeline will close (don't worry. It's saved,) and a new blank timeline will open. Left click anywhere in the new timeline, then right click and select "paste."
After a terrifying period when you think nothing is happening, your entire project will suddenly appear in the new timeline.
Save it with a new name, then try rendering again.
Nov 01, 2010 | Pinnacle Studio Ultimate 12 for PC
How to put .mov in pinnacle studio to edit
Welcome to Fixya,
.MOV file is not supported to used and import to your Studio 11. I suggest to you to go ahead and try to convert that file to mpeg or AVI.
Jul 15, 2010 | Pinnacle Studio Plus Version 11
Pinnacle studio 12 .stx fil
Hi and welcome to Fix yah,
I would suggest to you to finished edit your project and after that click on make movie tab or the number 3 tab of your Studio then do this procedure.
Disc Type : DVD
Audio Compression : PCM
Video Quality : Automatic
Use Progressive Encoding : NOT checked
Always Re-encode Entire Movie: Checked
Burn Options: Create Disc Content and then burn.
Current Media : Should show what DVD Disc should be used.
Target Media: DVD 4.7 GB
Copies : 1
Write Speed: lowest possible
Let me know what happen.
Feb 14, 2010 | Pinnacle Studio Plus Version 11
My pinnacle 12 project opens as an empty project in pinnacle 14
Welcome to Fixyah,
Suggest for that if ever that the project wont open to your Studio 14 go back to your Studio 12 and then render it as File and used either AVI or MPEG then after that import that to your Stduio 14 the re edit the video again,.
Regards,
Joey
Dec 14, 2009 | Pinnacle Studio Ultimate 14 for PC
Where are the captured videos kept, I am running out of space on my HD. I have edited and saved movies I want off to another disk, but the originals are still on my C drive somewhere
Search your computer for all files with an extension that you use for your video files, whether it be mpg, mov, avi, etc. When you installed Pinnacle studio, you determined where the files would be stored or let it go to pinnacles default setting. Go to my computer right click and do a search for files >25Mb and that should bring up at least some of your files. Then look at the location (folder) where they are stored and you will find all of the others in there as well. Burn, transfer and/or delete what you don't want any longer. You might also try to open pinnacle studios, start a new project and save it, to see where pinnacle stores it. The rest should be there. Good luck and I hope this helps.
Oct 27, 2009 | Pinnacle Studio MovieBox DV 9 (210100349)...
Make movie keeps timing out, render error
I have also been running into an MPEGENCODER.DLL error about 1/2 way through my 20 minute movie. I am able to Make Movie with a 6 minute version, but hitting this error time and time again. I have removed Virus protection and all unessential system tray loads; defragged drive; downloaded newest Windows drivers; downloaded newest NVIDIA drivers; running Win XP Pro SP3, Intel 3GHZ, 1GB RAM, 76GB/10K spin drive.
Jul 01, 2009 | Pinnacle Studio Plus 12 for PC
File/Folder Permission Message in Pinnacle Studio 11 Plus
Hello welcome to FIxya!
Here you can check this procedure on how to open your files again.
"1) Check your Recycle Bin
2) Do a Folder/File Search for each of the Grey Folder Project names. This will display all Folders & Files with that Project Name. You are looking for an .stx File. If it's there, right-Click on Project Name / Open Containing Folder & Copy it to your My Projects Folder. Then you should have both the Grey Folder & .stx File for the same Project name, showing in your My Projects Folder.
If the Search doesn't display a .stx File, you can create a new one, by Opening a New empty Project, which will create a My Movie Grey Folder & a My Movie .stx File, Save to your My Projects Folder. Delete the My Movie Grey Folder & Rename the My Movie .stx File to the same name as your original Grey Folder."
So ...after finding my "lost" movie file, with its file name, under Documents\Pinnacle Studio\My Projects i then went through the following procedures using your great advice Colour;
  1. Make a copy of your found "lost" movie grey film icon file by right mouse clicking on your lost file and choosing "copy". Paste the copy into another folder in Documents where you can find it if need be
  2. Then go back to Documents\Pinnacle Studio\My Projects and right mouse click onto your grey film icon. Choose "rename". Then rename your "lost" grey film icon to a new file name but do not put .stc at the end of the file name, if you are operating VISTA and Pinnacle 12. This is important because Pinnacle 12 won't recognise the file later if you have .stc in the file name
  3. Open Pinnacle and go to the File Menu
  4. Click on New Project
  5. Open File Menu again and click on Save File as
  6. Give the file a name such as "Movie 7" and save it
  7. Close out of Pinnacle
  8. Open up Documents\Pinnacle Studio\My Projects and observe that you now have 2 new files there ...a grey film icon file saying Movie 7 AND a coloured Pinnacle icon file saying Movie 7
  9. Delete the grey icon file with the file name Movie 7
  10. Now give your coloured Pinnacle icon file the exact same rename as your precious "lost" renamed grey movie icon file, using the right mouse click on rename proceedure as explained in No.2 above.
  11. Close out of Documents file
  12. Now open up Pinnacle again
  13. Go to Menu and choose Open Project
  14. There you will see the coloured Pinnacle icon file with the new name of your "lost" movie file.
  15. Click onto its coloured Pinnacle icon, and watch your "lost" movie come into view again
Nov 16, 2008 | Pinnacle Studio Plus Version 11
Pinnacle Studio Version 9 for PC Logo
179 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
