Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Tv issue I have a tv that when I turn it on the ring around the power flashes red but the picture doesn't come up. can this be fixed and and how much would it cost?
  • tinatienza Oct 21, 2008
    Trying to tern power on the ring blinks 3 times red light and no picture- Please advisr!!!
  • jwatkins32 Nov 03, 2008
    The ring around the power flashes when pressed but the TV does not come on what could be the problem?
I have the same problem was there a solution to the problem
Posted on Oct 21, 2008
Sony KV29X5U No picture, red light flashes 4 times then out then 4 times etc. Is this worth fixing?
What is the exact model number of the Sony TV? Check if the same issue occurs when connected to a different source device like DVD player or when the TV is not connected to the cable box. Disconnect the connected devices and turn ON the TV to check if the red light still flashes
Sep 28, 2016 | Sony Office Equipment & Supplies
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
May 03, 2008 | Toshiba 32HFX72 32" TV
When I try to power on the red light flashes then turn off tv never has sound or picture
You Tv is experiencing a issue with its power board. How many times does it flash?
There is a squence of flashes to pinpoint where the issue is.
Parts would be purchase at www.partstore.com , if you do not know how to fix the Tv you might want to bring it into a shop. Your looking about a $200 repair bill just as it sits.
But can you give me how many blinks?
Dec 05, 2011 | Panasonic TH-50PX50U 50 in. Plasma HDTV
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
How can I fix "Red ring of death" on my XBox 360
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death" or "Red Lights of Death" or "Red Ring of Doom"), instead of the one to four green lights indicating normal operation, represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the hardware failure occurs, or not at all. If the console freezes occasionally, the error will not necessarily follow. The technical problems seem to affect some generations of consoles more than others. e.g. Xbox 360 60GB This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console. The 3 flashing lights can also be caused by power surges; if the console is connected to an outlet that receives a power surge, it may have a failure and the 3 lights will appear as long as the console is plugged into the outlet. Turning off the console, unplugging all power cables and plugging them back in, and restarting the console will fix the issue in this case. hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
Sound of game playing but no picture
Do the following at your own risk
First take off hard drive on the 360. Then plug it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) i only say this because i didn't use the HDTV setting to fix it. then plug it into the wall with the 360 laying down not up and down and turn it on. (no picture but sound) with the 360 on take 1 towel folded it long ways and wrap it around 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. . if this don'ts help you now you have a red ringed 360 and you can send it in to get repaired since there is a 3 year warrenty for red ringed 360's.
hope it helps-but remember its risky
Aug 10, 2009 | Microsoft Xbox 360 Console
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Samsung LN-S3251D
We have the same problem we have had ours for 2 months, went to turn it off the and the tv froze, could not turn it off or change channel. We had to turn it off at the power point, now it will not turn on at all. The red light flashes but no picture.
Jul 05, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Flashing re light
TT Couple of issues here Heating or optical Either way here is a you tube step by step on how to fix this along with a microsoft basic starter link on this issue. Should solve this issue http://www.youtube.com/watch?v=ZjFKFkiQmvg http://editorials.teamxbox.com/xbox/1651/The-Red-Ring-of-Death/p1/ Hope it helps :0)
Sep 20, 2007 | Microsoft Xbox 360 Console
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
62 people viewed this question
Jerry Greenberg
Jerry Greenberg
