Question about Plantronics Explorer 320 Headset
Bluetooth connection I have put in the pass code and the phone wants to connect but it kicks it back and says it's incorrect
THE CODE SHOULD BE 0000, MAKE SURE YOU INPUT THE RIGHT ONE
Posted on Nov 01, 2008
Trying to pair my bluetooth with my phone and it' asking for a pass code i don't have my manual so I don't know what the code is
when u connect ur phone bluetooth to any other device it need a pass code! you have to give that from ur phone manually and the other device should have to put the same code so now u use the headset option to connect to the bluetooth not the normal bluetooth conectivity !
Sep 16, 2011 | Cell Phones
Why can't I connect to the bluethooth that is stored in my phone?
What are you trying to connect with bluetooth? You need at least 2 devices that you have to connect by a process called 'pairing', where at least one of them is 'visible' (this means it can be discovered by any bluetooth devices searching for it) and then you must start pairing. Both devices must agree on a pass code, for example 5555 and you must put this in both devices when they ask for a pairing code.
Jul 26, 2011 | Cell Phones
I need the pass code to pair with nokia n70
I see you want your BT headset to be connected to your Nokia N70.
The pass code will be 0000 to be able to get the BT headset connected, Also make sure the phone Bluetooth settings is set to be discoverable in the Phone BT settings OK.
Have nice day.
Jul 25, 2011 | Plantronics Explorer 230 Bluetooth Headset
How i connect my note book to my htc bia bluetooth
Hi,this is a detailed step on how to connect your htc to your notebook via bluetooth. STEP 1. Turn on the bluetooth of your htc which is accesed at the connnectivity settings of your phone.
STEP 2 Ensure you also put on the bluetooth on your notebook,most notebooks have a single button in front of the keyboard,to turn on the bluetooth. STEP 3 You now go to the bluetooth settings on your phone,and click on 'add device'.when you click on it,it requests for a pass code,when this is done for the first time,this pass code can be any 4 digits of your choice. STEP4 After entering the pass code on the phone,a pop up shows on your notebook requesting for the same pass code you entered on your phone. Ensure you enter the same pass code for both the phone and notebook,if not the devices won't pair via bluetooth.
STEP 5. After entering the pass code on the notebook,the notebook is automatically paired with the phone via bluetooth,afterwards you can be able to transfer files between the phone and the notebook via bluetooth.
Thanks and take care
Apr 21, 2010 | HTC P3450 Touch Black Unlocked...
What does it mean when i get password mismatched in the Bluetooth pass code?
password are for security and privacy reasons..
missmatched password while pairing bluetooth devices means you have entered incorrect pass code.
usually the the device A you are searching with asked you to create a pass code when you are pairing device B. When connection is establishing, device B will ask you for the pass code you just created for pairing device A with device B. this pass code is different for each and everytime you connect to a device.
Nov 05, 2009 | LG Vu CU920 Cellular Phone
EM227 ASKS FOR PASS CODE ..I DONT HAVE WHY?
The pass code should be 0000 but if you get it synced. It will not stay connected. Its not your htc phone. I went to HTC's website to get the bluetooth update, installed it, and im still having the same problems. Its the piece of s#*% em227 bluetooth that is the problem. Your best solution is to go and buy a new bluetooth cause yours, just like mines, wont work. Have A Nice Day
Sep 26, 2009 | Southern Telecom Emerson Bluetooth Headset...
How do I connect my bluetooth to my cell phone?
my phone i asking for a numeric pass key. what is the code for this ?
Mar 20, 2009 | NRS Technocel Clear Brown Cosmo Cell Phone...
HELP....
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Aug 13, 2008 | LG HBM-550 Wireless Headset
Lost manual
In addition to the power button, there should be two volume buttons on the side of the headset. Press and hold all three buttons to put the device into discoverable mode.
May 16, 2008 | LG HBM-710 Wireless Headset
Bluetooth asking for pass code???
The pass code can be what you chose and has to be entered on your phone and the device you are connected like your pda or laptop at the same time, so you have to enter the number into your bluetooth client on your pda or latpop at the same time as your cell.
Hope that helps.
Dec 08, 2007 | Motorola Mobility A780 Cellular Phone
Plantronics Explorer 320 Headset Logo
53 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
