Question about Braun Syncro 7680 Electric Shaver
Braun Syncro 7680
When i plug the shaver in to charge and clean the red charge indicater is flashing, it has never done this before. when it was new the light would stay on when charging. thank you in advance for youre help. DAVID
  • 2,961 Answers
The red light tells you it is cleaning, a green flashing light tells you it's charging
Posted on Aug 23, 2008
Why have I got a red light on the bottom of my shaver when I am using it
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here:
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
Nov 09, 2015 | Braun Health & Beauty
Shoud light red light flash behind charge indicater when switched on on hurricane
hi, is this still a issue, this is a fault ....
Mar 12, 2015 | Pride Hurricane 4 Wheel Personal Mobility...
My Shaver will not charge or turn on
Model 7526 is not a new shaver. It was made about 8 years ago. If no lights illuminate when the power cord is attached, the circuit board is bad. Unfortunately, Braun no longer makes internal parts for this model
If you like this shaver model and want a similar one, you will find one at This model uses the same shaving head as the 7526
Oct 27, 2014 | Braun Syncro 7526 Electric Shaver
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
How long does it take to charge?
Model 7680 takes 1 hour to fully charge
Sep 14, 2011 | Braun Syncro 7680 Electric Shaver
Excessive vibration with Braun razor
Most likely, the oscillator in the drive unit is broken. You will find this part for model 7680 at See link below for product and helpful disassembly video
Jun 09, 2011 | Braun Syncro 7680 Electric Shaver
I have a new ES-LA93 razor which I love but I have one question. After shaving I press the [SELECT] button to choose Clean/Dry/Charge. The process finishes and all seems fine but the CLEAN and DRY course...
If you clean the razor every day, the CLEAN and DRY lights flash repeatedly to show you that the cleaning has completed. You should be able to confirm that this is correct by NOT cleaning it one day. You should see that those lights don't flash then. I know this because I clean the razor twice a week rather than every day. On the days that I clean it, the lights flash. On the days that I don't clean it, the lights don't flash.
Nov 08, 2010 | Panasonic Health & Beauty
My 7680 clean and charge unit does not work
If it simply does not work at all, the circuit board is probably damaged. This is not repairable and you will need to buy a replacement. You will find a new clean and charge base at See link below
Oct 22, 2010 | Braun Health & Beauty
My Braun electric shaver model 7680 has stopped functioning probably due to a dead battery ( I had it for years). A service center is asking in excess of 60 dollars to fix it. Battery and mother board...
If the shaver is completely dead and the charging lights no longer illuminate when plugged in, the circuit board will need changed. If they still illuminate when plugged in, you can just change the batteries.
You will find the batteries and also the circuit board with batteries at You can order which you require. See links below
There is a tip on the battery page for easier installation has an instructional video that shows you how to disassemble the shaver at the link below. It's the 4th video down
Oct 14, 2010 | Braun Syncro 7680 Electric Shaver
Braun Syncro 7680 Electric Shaver Logo
566 people viewed this question
Top Braun Health & Beauty Experts
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
