Question about Samsung HCM4215W 42" Rear Projection Television
Samsung HCM4215W Turned on set...only the blue component activated for half a second, then it cycled to the red component before finally going black. All subsequent attempts to power on the television are accompanied by an electric static noise, but the TV never turns on.
  • 132 Answers
Unplug the power.
Remove largest plug from convergence board. Plug in TV, see if it starts. If it does, then a convergence IC is are shorted.
Repair convergence
Posted on Aug 24, 2008
Samsung hdtv scrfeen half black half res
Sounds like the color wheel is not turning properly. I would recommend calling 1-800-samsung to set up repair with an authorized service center. I would not try to replace it yourself. The part costs $120.00- $180.00.
May 26, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung 42" rear projection HD tv issue
pico fuses are those small on board fuses, usually soldered into place, that protect important parts of the board.
Feb 26, 2008 | Samsung HCM4215W 42" Rear Projection...
Red Convergence out on right side of the screen only
Projection TV sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Dec 08, 2008 | Samsung HCM4215W 42" Rear Projection...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 29, 2017 | Samsung HCM4215W 42" Rear Projection...
Color alignment problem
You will need to put the unit into wahts called service mode because it will have to totally realigned since you change the whole module you changed the chip that had you stored memory setting for convergence called an EEPROM. here in the shop I would unsolder the old EEPROM and put it on the new BOARD. Also on most models you don't have adjustments for the green you have to move red and blue to match green. Imay want you to describe again to me what you can adjust now with the new board in the unit can you move all colors left right and up/down
Mar 10, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung HCN4226W blue color outlines
Samsung parts for convergance problem
This convergence board works with the following Samsung television models: HCM4215W, HCN529WX, HCN559WX/XAA, PCN5425R, HCN4226WX, HCN529WX/XA
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Tv wouldn't turn on, unplugged convergence board, turned on, replaced STKs, still have convergence problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Feb 07, 2008 | Samsung HCM4215W 42" Rear Projection...
Need blue CRT for HCM4215W. Anybody got one for sale? Please help.
I live in Orlando FL, my HCM4215W tv works great.. but moving and want to sell it... if your local, its $250 for it...
Jan 12, 2008 | Samsung HCM4215W 42" Rear Projection...
HCM4215W Green convergence problem
Hi Greg,
Sounds like you have a bad convergence chip in the convergence board. Unfortunatly, about 80% of the rear projection sets I work on have this similar problem. I suggest that you change both chips ( there are 2 of the same ) and remember to use heat sink compound as this is why you not have the problem ( excessive heat destoys electronic components). Good Luck
NC Electronic
Mills, Wyoming
Dec 19, 2007 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
70 people viewed this question
Jerry Greenberg
Jerry Greenberg
