RCA G36695LV TV While we are watching TV the menu comes up on the screen for a short time, then goes away by it self. After this happens the only way to turn off TV is to unplug it. When plugged back in it will not work. After being unplugged for several hour It will work normal for a while than the same thing happens
  • 979 Answers
First, "hide" the remote. I believe that, from past experiences, that the TV is being acted on by a defective/stuck remote button. If that does the trick, the next step is to repair or replace the remote....accordianman
Posted on Jul 28, 2008
Weird colored bar
screen is starting to crash ,
Mar 23, 2012 | RCA 46 46LA45RQ LCD TV
Menu keeps coming on .
what is the unit model, and did you use the remote control or the panel of the tv in turning off or to exit the menu...?
Oct 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Dec 23, 2007 | RCA F38310 38" TV
Both when playing games via RCA or HDMI, and when watching cable, the tv screen randomly changes to verticle multicolored lines. If I unplug it and plug it back in, it may go all day with it happening...
The tvs shops will cost u like around $300-350 for the board part that call the T-CON board and labors.The board that call the T-CON board it is shorting out and dying to causes this.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-CON board for the replacement by ur self.The T-CON board probally will cost u like 80-90 dollars plus shipping.
Jul 15, 2011 | LG 42LC2D 42 in. LCD HDTV
Dish menu but no picture or sound
Try holding the power button in on the receiver until the picture goes away then turn it aloose it will reboot and your sound will usually come back. If you had rather and can get to it unplugging it from the electric outlet, the receiver, does the same thing.
Oct 21, 2009 | Televison & Video
Black square appears on my Legend TV
Check to see if you have text turned on in the closed captioning menu.
Jul 26, 2009 | Televison & Video
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
RCA 52" Menu Keeps Popping Up and Down
I see this alot at the shop ... the front panel buttons have become damaged. THe best coarse of action is to replace the front button cuircit board assembly... **** there is a tempery fix untill you get the part... remove the front panel and take button cuicit board out...just use remote to control the tv. This is also a way to test to see if this is the problem.. if you romove the connector to the buttons and the problem goes away then the buttons are the problem. you get get this cuicit board at union electronics. You have to get the extended model number off the back ussally d52w20yx1 or yx2 or yxsomething...not to difficult a repair
Nov 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
ON/OFF
turning off mute with no remote on a rca reciever
Dec 23, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
