i bought a graco snug ride infant car seat used and i need to know how to install the base in my ford expedition.i bought a graco snug ride infant car seat used and i need to know how to install the base in my ford expedition.
I just bought a used graco snug ride infant car seat model #7304ge12, and I dont have the manul on how to properly secure the base in my car. I have a Ford Expedition.
Safety 1st do not produce adaptors for a Graco carseat to be fitted to the DuoDeal Tandem. This stroller chassis is not designed to be used with a carseat.
You have two options with this depending on child size. The most common is through the slots in the back behind the cover then tightened. The other option with larger kids or for quick removal is to strap it over the the lap of the carseat.
Recline the stroller seat. There are probably little plastic handles on each side of the stroller seat that you push in while you stand behind the stroller, to recline that seat. Then, you put the carrier into the stroller, facing the back of the stroller. The little notches in the bottom of the carseat fit right onto the edge of the stroller tray. You can test that you've done it right by pulling upward on the carseat. It should not come up and out of the stroller unless you pull the red handle on the back of the carseat as you life the handle of the carrier. I hope this helps!
hmm thats easy, theres big hole in the base stream the seatbelt through thsoe and tighetn, if u have ltch., EVEN BETTER! they should already be attached but if not feed through the same holes as regulare seat and tighten (i personally kneel in the base to tighten them up!)
Same here
