Question about Adesso WKB-4000US Keyboard Touchpad
Computer doesn't recognize keyboard - Adesso WKB-4000US Keyboard Touchpad
    New Friend:
  • 31 Answers
Try shutting off the keyboard then turning it back on and using the quick connect button. Keyboard goes into a powersave mode every 5 minutes and could be disconnecting. It is also on 2 Ghz technology so a cordless phone could be interfering with the signal.
Posted on Feb 28, 2011
SOURCE:
Need to be able to connect to my computer . plugged it in but computer does not recognize the mouse . red light is on
My computer doesn't recognize my mouse and its not listed in ...
www.tomshardware.com > ... > Windows 2000/NT
Tom's Hardware Guide
Mar 25, 2012 - 9 posts - ‎7 authors
please help.....I am using my keyboard to move my mouse keys and it really sucks. After a storm everything came out fine on my diagnostic ... My computer doesn\'t recognize my mouse and its not ...
Feb 28, 2013
Mylaptop doesnt recognize the usb for my mouse ...
Jan 27, 2013
Computer won't recognize keyboard or mouse - Mice ...
Aug 27, 2012
Computer won't recognize keyboard or mouse? [Solved ...
Aug 6, 2011
More results from www.tomshardware.com
Mouse doesn't work in any USB port - Tom's Hardware
Jan 21, 2016 | Onn Optical Mouse
Mouse Problem
First, let's see if the computer is recognizing the mouse. Unplug the mouse, restart the computer, and then re-plug the mouse. Typically, the computer, in the bottom right side of the screen will attempt to re-establish connection to the mouse.
If it does not, then re-downloading the driver for the mouse (if a disc was not provided with it) will help the computer recognize the mouse and the connection.
Hope that helps.
May 18, 2013 | Computers & Internet
Computer doesn't recognize ez eyes keyboard
unplug the keyboard, go to the manufacturers website and download and install the drivers, plug the keyboard back in.
If that doesn't work
check your device manager and see what keyboards are in the keyboard section. delete anything but the hid keyboard device and the standard ps2/2 keyboard from the keyboard section. repeat the first set of instructions
if that doesn't work either
take the keyboard back it is most likely faulty
Aug 25, 2012 | Toshiba Computers & Internet
Keyboard problem & it doesn't work prefect
If the keyboard has a round purple connector, power down the computer then unplug and then plug in the keyboard. Power on the computer. If it works your done if it doesn't replace the keyboard. If this is a USB keyboard, with the computer on, unplug and plug in the keyboard if it works great, if it still isn't working replace the keyboard. NOTE if this is a multi functional keyboard (special keys at the top) make sure you install the driver and any software associated with the keyboard.
Jun 11, 2012 | Computers & Internet
My KEY BOARD IS NOT WORKING
1. Restart your Computer at once. 2. If it doesn't work Turn off your computer and remove the keyboard from your computer and replace again. 3. If it doesn't work too, you need to change the key board. thanks
Aug 30, 2011 | Gateway 2520915 Keyboard
USB light for microsoft 3000 wireless keyboard/mouse not turning on. Keyboard and mouse not responding at all. Tried everything I could think of.
Go to Microsoft/help/support.com and you should find a solution. Sounds like you don't have the right hardware or a bad software pack. Also make sure the computer recognizes it. Try another keyboard if you have access to one. You'll probably have to go to another computer to get instructions and print then out and maybe you can do it with a mouse if it works and another keyboard doesn't work. If you can get another keyboard to work and download the drivers for the 3000 make sure the 3000 is plugged into the computer when you download the driver for the 3000.. They do have downloads for the 3000 I just went and looked and the last keyboard I had was a 3000 and I downloaded files from Microsoft. Hope this cures your Microsoft headache; dhgill1949
Jun 04, 2011 | Microsoft Wireless Desktop 3000 Keyboard
How do I setup my wireless mouse and keyboard
Need more information but normally you would hook up the infrared device or usb device to the laptop. Then you would make sure that the keyboard and mouse has new batteries in it. At that point windows should recognize the mouse and keyboard. You may have to push on the connect buttons on the keyboad or mouse to get the laptop to recognize them.
Other then that its not really hard. Just time consuming if it doesn't take right away. Most of the time you don't need software installed unless the manual tells you to install them because windows will recognize them.
May 29, 2011 | Acer Aspire Z5600 PC Desktop
A program deleted my keyboard and now I don't have one showing when I check the keyboard in my control panel. It works at the very start up but not after. I have tried a new keyboard and windows doesn't...
Generally additional drivers are needed for basic keyboard functionality, although Windows does actually install them as unique devices. Sometimes this process can take several minutes (depending on computer speed) and the keyboard will be unresponsive until it's actually installed. Try plugging in your keyboard, rebooting the PC, and giving it a few minutes once it's up and running.
If that doesn't work you can try booting into Safe Mode by hitting the F8 key during the startup process. This will load generic drivers and will allow you to troubleshoot additional drive and/or software issues.
May 02, 2011 | Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
CD driver do not read any file
Does it recognize any cd you put in the drive or is it only one cd it doesn't recognize?
Please check if the cd drive is recognized by your computer:
Click Start go to My Computer (XP) / Computer (Vista/Win 7)
and check if you can see the drive. (if it's not there you may have to reseat the drive to make sure that the cables connecting it to motherboard are tight)
check the status in the Device Manager:
On your Keyboard press and hold the Windows Key then press the letter R
once the Run box comes up type in devmgmt.msc and the device manager should appear.
On the device manager look for the cd / dvd drive see wether it has an exclamation point a red x mark or a down arrow or it looks normal.
if it has a yellow exclamation point press and hold the windows logo then the letter R again and type regedit:
On regedit go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and the delete the upper and lower filters. Close Regedit and restart the computer.
if it has a red x mark right click on the cd drive in the drive in the device manager and the choose uninstall and restart the computer.
If it has a down arrow right click on the drive and click Enable.
If the above steps doesn't work or if it doesn't recognize all types of media you put in it, that might mean that your cd drive is busted and it needs to be replaced.
Hope you find this helpful!
Apr 30, 2011 | LG CRN 8245B (CRN-8245B) Internal 24x...
External keyboard doesn`t work
hiiii ther
how r u ??
1st i don't recomand teh vista to ur machine
it's not VERY comabtble even acer co. say it's ok
ur problem it could be one of two reasons
1 the adapter is makeing a conflict
2 the vista not recognizeing the USB device
so 1st try to make sure that the vista recognize USBs device
than try to change the adaptor
if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Nov 20, 2008 | Acer Aspire 7720 Notebook
Adesso WKB-4000US Keyboard Touchpad Logo
228 people viewed this question
Top Adesso Computers & Internet Experts
mark
mark
Alun Cox
Robert Salgado
Robert Salgado
Are you an Adesso Computer and Internet Expert? Answer questions, earn points and help others
