Question about Pioneer inno2 Portable XM Satellite Radio Receiver with Home Kit - Black
Pioneer Inno Gex-INNO2BK stuck in re-boot cycle
My Pioneer INNO2BK is stuck in the boot-up cycle. It restarts the cycle at the powering up screen and repeats until it is placed in the Home cradle.
This also happens in the car cradle. It does not aquire a satelitte signal durning this process.
I fixed the reboot cycleing problem by plugging the travel charger into the jack that also fits the home and car cradle. I had the Inno set to auto start when it was powered on in the car cradle. The travel plug must have over-ridden the auto-start setting and allowed it to finish the complete bootup. I then reset the Inno default settings and every thing was back to normal. I do not know what was the original cause of the rebooting cycle problem
Posted on Jul 28, 2008
Won't power on
Have you tried plutting it in directly to the power source with out the battery? If this works, it may be that the battery is dead, you can try to jump it by putting the battery in after it has already been turned on. Or just replace the battery:
http://www.tss-radio.com/products/replacement-battery-for-pioneer-inno-and-samsung-helix-xm-radios
If it does not power on, it could be the power cord is bad:
http://www.tss-radio.com/products/xm-5v-home-ac-power-adapter
Otherwise, the unit itself may just be dead.
Jun 26, 2012 | Pioneer GEX-INNO1 XM Radio Receiver with...
Pioneer GEX-INNO2BK XM Radio Receivers backight problem
Have you tried changing the backlight controls in the menu? Pull up your menu, go to settings, then preference, and change display. Choose backlight display. You can put it always off, always on, or on for however many seconds.
Jun 05, 2010 | Pioneer GEX-INNO1 XM Radio Receiver with...
Pioneer Inno - Powers on, great signal - but audio or pad data!
I'm assuming the power button it not in 'hold' position, and you have the volume turned up, and/or on the correct frequency with the adjoining radio?
May 27, 2010 | Pioneer XM2go Inno Satellite Radio...
Portable gex-mp3 gets stuck on powering up
The battery is definately the problem. I have seen many times in this device in particular - the battery shorts to ground - and causes the unit to malfunction.
VERY COMMON and recurring problem in the GEX-MP3
CLICK HERE to read more.
Replacing the battery is as easy as finding an Authorized Pioneer Repair center near you.
Pioneer does not sell parts to unauthorized repair techs.
CLICK HERE to find the nearest one to you. (top right of page)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 08, 2010 | Pioneer GEX-INNO1 XM Radio Receiver with...
Volume control
Remove the back battery cover only. Turn unit on. Insert a tiny paperclip thru the tiny 'reset' hole on the back of the unit inside the battery compartment. OK?
Aug 05, 2009 | Pioneer XM2go Inno Satellite Radio...
White screen
I had the same problem with my Pioneer Inno Gex-Inno2BK XM radio receiver. One evening while leaving work, I gently took it out of the cradle & the screen suddenly went completely blank & all white. I could still hear music but there was no screen visible. Solution is this: (1) Gently remove the back cover which covers the battery. (2) Gently remove the dark blue square battery which is only about 1 inch (width) by 3/4 inch (height) by 1/4 of an inch in thickness. I removed mine by holding the receiver upside down & gently shaking it with one hand until the battery came out into my other hand. After about 4 or 5 gentle shakes, it came out. (3) Wait about 10 seconds. (4) Place battery back into XM radio receiver being careful to line the copper power receptable on the battery with a corresponding surface inside the receiver. Each copper area is only about 1/10 of an inch by 1/10 of an inch. Use this as a guide when putting the battery back in to make sure it's lined up properly. (5) Gently slide the cover back in place & let it snap into place. (6) Turn receiver back on by pushing power button like normal. (7) XM receiver should boot up with a full display just like new. All recorded songs are still in place. Nothing has been lost. Problem solved. Root cause of problem is probably some type of boot-up issue with the receiver in which the battery (i.e., the power supply) just happened to be slightly ajar...which also persisted even when placing the receiver back in the cradle until the above steps were taken. The steps above worked beautifully for me...Hope it works for you as well! Have A Great Day...Tom Armstrong
Jan 19, 2009 | Pioneer inno2 Portable XM Satellite Radio...
XM radio express blank screen
I had the same problem with my Pioneer Inno Gex-Inno2BK XM radio receiver. One evening while leaving work, I gently took it out of the cradle & the screen suddenly went completely blank & all white. I could still hear music but there was no screen visible. Solution is this: (1) Gently remove the back cover which covers the battery. (2) Gently remove the dark blue square battery which is only about 1 inch (width) by 3/4 inch (height) by 1/4 of an inch in thickness. I removed mine by holding the receiver upside down & gently shaking the battery with one hand until the battery came out into my other hand. After about 4 or 5 gently shakes, it came out. (3) Wait about 15 seconds. (4) Place battery back into XM radio receiver being careful to line the copper power receptable on the battery with a corresponding surface inside the receiver. Each copper area is only about 1/10 of an inch by 1/10 of an inch. Use this as a guide when putting the battery back in to make sure it's lined up properly. (5) Gently slide the cover back in place & let it snap into place. (6) Turn receiver back on by pushing power button like normal. (7) XM receiver should boot up with a full display just like new. All recorded songs are still in place. Nothing has been lost. Problem solved. Root cause of problem is probably some type of boot-up issue with the receiver in which the battery (i.e., the power supply) just happened to be slightly ajar...which also persisted even when placing the receiver back in the cradle until the above steps were taken. The steps above worked beautifully for me...Hope it works for you as well! Have A Great Day...Tom Armstrong
Dec 15, 2008 | Pioneer GEX-INNO1 XM Radio Receiver with...
Pioneer inno
The problem is caused by a glitch in the firmware that came on your Inno. It can be easily fixed by downloading a free firmware update at http://fwupdt.xmradio.com.
Aug 29, 2008 | Pioneer XM2go Inno Satellite Radio...
Pioneer inno2 Portable XM Satellite Radio Receiver with Home Kit - Black Logo
809 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
