Question about Fisher and Paykel GWL11 Top Load Washer
Washer is making grinding noise, and leaking
My washer machine was leaking water under front right side. then a few days later, it starting making a grinding sound and now won't complete the cycles.
  • 95 Answers
Check the motor and pump seals for damage.
Posted on Aug 10, 2008
Frigidaire front load washe makes an awful noise when water starts to drain
Yes normally remove the bottom panel and the pump is in the front on the right side. Some companies recommend you clean it every few months. Also some will let out water when you open it up, so have a towel ready.
Apr 14, 2014 | Frigidaire Affinity ATF7000E Front Load...
My washer makes a grinding noise and leaks out the bottom
washer makes a sqeeling noise where fan belt is attatched but only in one direction.could the machine need rebalancing?
Feb 21, 2013 | GE WBSR3140DW Top Load Washer
LG front load washer.Will not spin and makes loud grinding noise
what is your model number is then we can get started then to get your unit fixed all redy
Jan 22, 2013 | Washing Machines
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have purchased a Maytag washer mtw6300tqo and it leaked from the first day it arrived. It does not leak DURING the cycles but leaks profusely a few hours later. I have had service techs look at it and...
Is there water inside the tub after it starts leaking? If so the valve that lets the water into the machine could have a bad seal and overfilling the machine with water when it is not being used. Or one of your water hose seals could be leaking. Make sure the hoses are tight. Beyond that there is nothing to cause a profuse amount of water when the machine is not being used.
Apr 26, 2008 | Maytag Dependable Care LAT9206
Maytag MAV7700, Grinding and water leak
open the front with a puttyknife there are 2 clips about 4" in on each side this wil open the top so you can remove the 2 screws holding the front panel on once removed you can see the guts of the unit..Let me know if you need more help
Jan 28, 2008 | Maytag MAV7600 Top Load Washer
Maytag atlantis washer making loud grinding noise
The belt are tear and slap to the near obtacle need to replace /
The water magnetic valve are leaking ned to replace /the coil open or valve rusted.
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
During agitation it sounds like it is slipping and grinding
It could be a number of issues really.  Smaller issues could be something under the agitator, etc, to moderate problems, like a motor coupler, loose basket, etc.  Could also be a major problem like a motor or transmission.  A lot of times its the motor coupler or pump making the noise.  Both are pretty easy to replace.  Maybe some more information.  Do you happen to know where the noise is coming from?  Is it coming from the front of the cabinet or in the basket area?  Any small water leaks?  Does the spin cycle work ok?  Let me know some other information and maybe we can narrow down the problem to one particuliar area.   Jim
Oct 17, 2007 | Kenmore 24032\24036 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
196 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
