I have a RCA MM52110JX2 and it just started giving me troubles. When you push the power button it lights up and you hear something click inside and then the green light goes off and the TV never comes on. Someone told me that this could be the switch. What do you think? Thanks Andy
jack_daniels
  • 304 Answers
SOURCE: Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
Posted on May 26, 2008
ladywinn
  • 5138 Answers
SOURCE: 52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Posted on Dec 09, 2008
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
SOURCE: my 60 inch rca rear projection tv will not come on
i have had same problem repairman states splitter is bad has an upgrade for $350.00 the next time repaior man could not find part,,advised he would have to replace entire box this cost $275.00 and also states thiis would be a later model than my original box,the picture is great never been this good.note when i say box i ment the box inside tv with all the electronice and projector
Posted on Mar 27, 2009
SOURCE: mitsubishi WS-55909 dm board repair
I have the same exact problem with the mitsubishi ws-55809 I get 2 blinks pause 2 blinks when I do the menu and input buttons but I have no idea what it means.
Posted on May 31, 2009
My LG Plasma 50PK550 doesn't show a picture when I push the power button. It will also shut off when I push either the Input or channel buttons.
Main digital board fault. Check and replace the main digital board. Contact any service technician. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Jan 27, 2017 | LG 50PK550 50 HDTV Plasma TV
No Picture/No Sound
This is very possibly a power surge, can you tell me how many times the light blinks, you probably have a bad power board now if you had a power surge.
Aug 11, 2007 | RCA HD52W59 HDTV Projection Television
RCA MODEL D52W19 I PRESS THAT POWER BUTTON GREEN LIGHT FLICKS FOR
try unplugging the tv for a few hours. then plug it in and push the power button on the front of the tv.
it has something to do with this processor issue inside the tv....its pretty much a stupid thing.
should have been a recall because everyone has the same problem on here.
this is pretty much just a band-aid over cancer, but i've been having to do this for about a month now, and it works.
Apr 10, 2009 | RCA D52W19 52" Rear Projection Television
RCA-- Mod# G35310WKL
Ok just to test something try and rocking the televition forward and see weather that turns it on for a slight second or more and get back to me
Jun 23, 2008 | RCA Televison & Video
Wont turn on
Hi ,your trouble could be a 2200 35v cap on the high voltage power supply,its in the middle of the board behind a little u shaped heat sink,the cap is green and if its bad the top will be pushed up,hope this helps
Oct 14, 2007 | RCA D52W19 52" Rear Projection Television
Powers off by itself
Usually leaky power supply diode and two bad caps-----need service # and chassis # from sticker on back of set .....T.
Jan 22, 2007 | RCA 32V420T 32" TV
Rca p46771at won't come on post lighting.
Have you tryed to unplug for a while and plugging back in again.. Ff that dosent work, something most likly in the power suppply blew out from a power surge.. if your not a tech or have TV experience it would be best to leave this to a pro. Too much Hi Voltage inside these sets to fool around with and do any experimenting! good luck
Jul 25, 2006 | RCA P46924 46" Rear Projection Television
Have you tryed to unplug for a whiloe and plugging back in again.. if tha6t dosent work, something most likly in the power suppply blew out from a power surge.. if your not a tech or have TV experience it would be best to leave this to a pro. Too much Hi Voltage inside these sets to fool around with and do any experimenting! good luck
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
