Question about Kenmore 24 in. 15142 Built-in Dishwasher
Draining problems I recently saw my dishwasher not draining. I am not familiar with trying to fix these ptoblems on my own and don't have money for someone to come out. Any info greatly appreciated.
  • rahtn Aug 07, 2008
    The washer will not drain. It does not even act like the pump is trying to drain.
    Sergeant:
  • 359 Answers
THIS COULD BE A HOST OF THINGS BUT THE ONE MOST COMMON WITH THE SIMPLEST FIX IS WHERE THE DRAIN HOSE CONNECTS TO THE PLUMBING ,SINCE THIS IS USUALLY A TEE OR AT LEAST A WYE THIS IS THE MOST COMMON PLACE FOR A STOP UP AND WOULD BE MY FIRST LOOK SEE TO ADDRESS THIS PROBLEM , USUALLY A HOSE CLAMP AND DOES NOT REQUIRE PLUMBING SKILLS AND MIGHT GET LUCKY
Posted on Jan 13, 2009
How to fix samsung dishwasher code se
The code is 5E
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose.
If the drain hose is kinked, there will be an excessive amount of water in the bottom of your dishwasher after a cycle has been completed.
In order to access the drain hose you need access to the back of the dishwasher. If your dishwasher was recently installed, contact the installer to move the dishwasher and inspect the drain hose.
If the drain hose is not kinked, but your dishwasher is still not draining, service is required.
Apr 21, 2015 | Samsung Dishwashers
A friend gave me this dishwasher with this model number and I don't know where to connect the drain line
i recently installed a dishwater and had to hook the drain up to my garbage disposal line and have no problem
Jul 24, 2012 | Frigidaire FDB1050REM Dishwasher
My dishwasher won't drain and there is a rattling noise in the door. I don't know if I should just get a new one as the repairman costs are high. I did start a cyle over and more water went in but...
there is a drain pump system on the machine could be clogged, also if the drain hose is not installed up and over the unit it will cause issues with drainage. as for the rattling noise you probably have either pieces of broken glass rolling around under the basket.if you are a do it your self-er its always fun to explore.if not the cost of repair would be the cost of a new install. don't waste your money.
Jun 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Hello, I am having problems with my Kenmore energy star dishwasher. It's not draining properly and the dishes don't look clean. The glassware looks cloudy. The last few sessions I also...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 25, 2011 | Kenmore Dishwashers
Dishwasher does not drain
Do you hear the motor running during drain cycle? If so, there is likely a blockage inside the motor (rotor) chamber and filter sump.
You will have to take the rotor out and lift the filter plate. There is a small channel between the rotor chamber and the filter sump. Take a thin but rigid wire and remove any obstacles. Mostly chicken bone fragments.
If motor is not running during drain cycle, then you are looking at a bigger problem and will require checking if the wash cycle is ever completed. If not, then the heater could be the problem. Will need technician if you are not familiar with fixing such things.
Please rate the solution if you find it ok, Otherwise post a comment and fixya.com will try to help you.
May 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have the same SE error message on my Samsung dishwasher.
I got SE error on my Samsung. I need help how to solve this problem? Please help!
Jul 19, 2009 | Samsung 24 in. DB5710DT Stainless Steel...
We recently bought a house with a Kenmore 363.16222100 (?) dishwasher. No manual. Monday night it didn't drain properly and leaked some water on the kitchen floor. The cycle had finished when we saw the...
Hello
Welcome to Fixya
My name is Huum,
You can find your model dishwashers manual here at this site. this site
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0801624.pdf
I feel you should not invest blindly in someone else s old dishwasher with no history.
Buy your self a new one
It will be much more energy efficient too!
Please remember to leave a rating before you leave
Dec 10, 2008 | Dishwashers
BOSH SHU43 dishwasher
From my experience.. usually when a motor is humming it could be something is stuck in your impeller.. if your can get to your drain pump to check it out.. and getting to your drain pump can be a pain.. good luck.. hopefully that works
Jul 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher will not drain. General Electric 4200 series
Dear friend,
ngfam at you service! happy to assist!
Check for debri and food at the bottom clogging the drain. Be care full of your fingers in case there is broken glass don there!
Other wise it may be a weak pump and then you better call service
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Jul 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dish washer??
Has a disposer been installed recently? If so the drain plug may not have been removed...... Some DW have a check valve attached to the sump that may have a blockage..... Remove the drain hose from the disposer, if connected to one and inspect for blockage.
Jun 01, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
Kenmore 24 in. 15142 Built-in Dishwasher Logo
111 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
