Question about Bunn BT10B Coffee Maker
I have lost the manual for my bunn coffee maker and i went on line to the bunn corp and my model # is not listed it is a BT10-B I need to dump the water from the water well and I can't remember how to do this without turning the coffee maker over and I know you are not suppose to do it that way can you help
    Problem Solver:
  • 12 Answers
  • 60 Answers
Go to Bunn's site - here is the link for the manual:
http://bunnomatic.com/pdfs/commercial/manuals/37688.0001.pdf
Posted on Jul 28, 2008
I have a BUNN BT10-B Coffee Maker that started leaking. I believe it it is the gaskets between the top trank and the heater. How do I het these gaskets new?
The seal kit is available free of charge through Customer Service at Bunn. If you will call 800-352-2866 and have the model and date code from the bottom of your brewer and we will be happy to assist you.
Jan 16, 2011 | Bunn BT10B Coffee Maker
Need the lid seal or gasket for a BUNN BT10-B
Please call customer service with the model and date code and we will be happy to assist you with this problem. The number is 800-352-2866.
Sep 14, 2010 | Bunn BT10B Coffee Maker
I have a Bunn BT10-B coffee maker. I need the two rubber parts to replace the old ones which is causeing it to leak.
If you will call 800-352-2866 with the model and date code, we will be happy to help you.
Jun 15, 2010 | Bunn BT10B Coffee Maker
I'm helping a friend fix heater problem with the Bunn Model BT10-B. I've taken it apart. Surprised to see there is no lift tube with check valve for the hot water. Only see a small silicone connector at...
If you will bet the model and date code located on the bottom of the brewer, the machine can be replaced. If it is 3 years old or less, then it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced cost.
Oct 15, 2009 | Bunn BT10B Coffee Maker
When pouring coffee it drips, also doesn't keep coffee hot
Hi - Any time I've had an issue with my Bunn BT10-B, I go to the website, www.bunn.com , and go to their Customer Service area. They have been extremely helpful and informative.
Aug 16, 2009 | Bunn B10 Coffee Maker
I have a bunn coffee maker, BT10-13. The reserve water takes very long to reheat after making a pot of coffee. Thus I can't make a second pot of coffee for a long time.
Are you rapid firing your coffee maker?Not designed to do that.. If the water heated that fast it would boil dry if you ever left it unattended and on. The reservoir is heated with the time it takes to drink a full pot taken into consideration for reheating.. If you are serving 20 cups with a 10 cup machine, Expect a delay, especially if you are refilling with cold tap water. Sorry.
Jun 30, 2009 | Bunn B10 Coffee Maker
Bunn BT10-B silicone washer
Yes, you can get a washer from your local Bunn repair shop. For a list of repair facilities in your area, go to www.bunn.com And yes, the heat is a problem, so you can't use just any washer.
Jan 24, 2009 | Bunn BT10B Coffee Maker
Bunn omatic model F20 doesn't stop dripping
Check out:
http://whles.com/General%20Mtx%20Knowledge%20%20Tony%20Roach/BunnOMatic%20F35%20F20%20F15%20x.pdf
This is the free full service manual F15, F20 & F35 complete with troubleshooting section at the rear. This section has easy, plain english steps to follow to solve this very problem (others, too).
Oct 02, 2008 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Bunn coffee maker bt10-b is tripping gfci. I had leakage from the tank, and after fixing, the gfci problem started. I suspect the zig-zag wire that is wrapped around the bottom of the tank has some water...
The heating element inside is problably broken. Thats what mine does. just disconnect it and you will see that cures your problem. You cannot buy parts for this. I have tried already.Junk
Jul 10, 2008 | Bunn BT10B Coffee Maker
Bunn BT10B Coffee Maker Logo
283 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
