Question about Nikon Cameras
I put on a telephoto lens on my camera and on the display the white parts flash black and white. I switched it back to the lens that came with the camera and now it's doing it with that too. How do I fix it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
You're looking at the blown-out highlights. These are areas where you've lost all detail. Press up/down on the multiselector to change the view. Better yet, reduce the exposure to reduce/eliminate them.
Posted on Dec 31, 2009
Canon g11 telephoto lens vignette
You have to zoom the camera lens out for that lens to work.
Feb 15, 2014 | Opteka 32x HD?² Telephoto Lens for Canon...
Images are black
Did you set your aperture your ISO and speed
please put it in Automatic if you dont know how
Dec 01, 2013 | Nikon D3100 14.2MP Digital SLR Camera with...
Black at the bottom of the pictures
Possible causes :
1. dirt or dust in camera or lens
2. dirt on sensor
3. sensor is cracked
If you are using the built-in flash and a telephoto lens, the end of the lens can block some of the light from the flash and that appears as a slightly rounded black "hump" at the bottom of your picture.
May 30, 2010 | Nikon D50 Digital Camera
I have a Nikon D50 black image on bottom of screen what is causing this problesm
Jan 21, 2010 | Nikon D50 Digital Camera
Lens Adaptor
The best source for the lens adapter is eBay.
Jan 08, 2009 | Kodak LENS ADAPTER 49 TO 55MM Lens...
Flashless photograghy
If you set the camera to P (program) the flash will not pop up automatically but the camera will still control the shutter speed and aperature settings automatically. Also with the lens you are using you should probably have a tripod which will help you hold the camera more steady.
Jun 10, 2008 | Canon EOS 40D Digital Camera
Lens
You have a 55mm filter size on your camera, and the accessory lens requires a 62mm camera connection. I think you are looking through a 55mm tunnel into a 62mm lens (over-simplified I know). The black ring is the result, and I don't think you can fix that. Is the telephoto a Panasonic accessory, or a third party item. I think I already know the answer to that. I'd take it back and see what Panasonic recommends - you'd be happier. However, Panasonic has Leica glass (Leitz lenses) so it won't be cheap.
May 19, 2008 | Panasonic Cameras
Adding a telephoto lens
Try zooming in. That usually gets rid of the "vignetting" you are experinecing.
May 02, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
Telephoto lens for digital camera
It will not work because it is the wrong thread size. Here is info on the Olympus TCON-17 lens for the 5050: TCON-17 (1.7X) Telephoto Conversion Lens Extend the capabilities of your digital camera with the TCON-17 Telephoto Converter lens. This telephoto lens will increase the magnification of your subject by 1.7x when your camera lens is set to the telephoto position. This will help you bring in the subject when you can't get closer, for example, shooting sports or concerts. Please see below for additional items required to attach this lens to your camera. The following models require the CLA-1 and 43-55mm Step-Up Ring: C-2000/2020/2040/3000/3020/3030/3040/4000/4040/5050 Zoom ....... The video lens is too small (diameter). If you found one with a 43mm thread and put it on the 5050, you would experience severe vignetting (clipping of the corners of the photo).
Sep 05, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Cameras Logo
18 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
