SanDisk 4GB microSD High Capacity Memory Card Logo
Anonymous Posted on Feb 24, 2011
I want to download a music to my microsd - SanDisk 4GB microSD High Capacity Memory Card
Anonymous
Level 3:
President:
  • Master 2,246 Answers
  • Posted on Feb 24, 2011
Anonymous
Master
Level 3:
President:
Answers
2246
Questions
0
Helped
514871
Points
7384
Insert you memory card to computer, use card reader
at computer open windows explorer
chose the music that you want to download to micro sd
then right click chose copy
go to micro sd drive then right click then chose paste
done
1helpful
How can I download music to my fusion2 phone
First you:
2.9.1 Using the microSD Card as USB Mass Storage
To transfer all your favorite music and pictures from your PC to your mobile phone's microSD card, set the microSD card as USB mass storage.
1. Connect your mobile phone to your PC with the USB cable provided. Your PC will detect the microSD card as a removable storage device.
2. Open the notification bar, and then touch USB connected.
3. Touch Turn on USB storage in the dialog box that opens to confirm that you want to transfer files You can now transfer files from your PC to your mobile phone's microSD card. When your microSD card acts as USB mass storage, your mobile phone will not use this memory space. Ensure that you follow the correct procedures to disconnect the USB mass storage device (your mobile phone) from the PC when you have finished transferring files.
Then:
8.3.1 Copying Music to the microSD Card
1. Connect the phone to your computer with a USB cable and mount the microSD card.
2. On the PC, navigate to the USB drive and open it.
3. Create a folder in the root directory of the microSD card (for example, Music).
4. Copy the music from your computer to the folder you have created.
5. After copying music, unmount or eject the drive as required by your PC's operating system to safely remove the mobile phone.
6. Disconnect the mobile phone from the PC.
Once done open music player and play music.
Ref: http://www.att.com/support_static_files/manuals/ATT_Fusion2.pdf
How to download a music to my microsd
Hi
Use any electronic device like computer when downloading and then transfer it to microsd Card by inserting it to the device.
Add music directly from mac?
If your Mac system has a MicroSD reader, you can add music directly from MAC to the MicroSD Card. You can also insert the MicroSD card into USB compatible phone connect the phone to your MAC and Load your Music to your MicroSD card.
4helpful
How do i download musicfrom my computer to my kyocera x-tc
The only way that I found is to use a MicroSD card that I can connect to my computer.
Put the MicroSD card into the phone first, the phone will add 2 folders, My Music and My Pictures.
Then, put the MicroSD card into the computer and copy the songs directly to the My Music folder. Do not copy album folders into the My Music folded, it won't find the music in them.
1helpful
Unfortunately, my son lost his IPOD. How do I
You can't use itunes to transfer his music to the phone, but you can do it manually. The matrix supports a microSD card, so you would need one the size of his library at least. If you have a microSD card, I'll assume you have a card reader. Just go to My Music on the computer and there should be a folder called iTunes, and within that folder one called iTunes Music. Just copy the contents of that folder to the microSD card and then put it in the phone. He should now have his music on the phone.
I CAN`T PUT MUSIC IN IT
Make sure that the microSD card is formatted. You may reformat the memory card using your phone and then try saving some music.
If that will not do any help, try using another microSD card to see if the card is defective.
Have a great day!
3helpful
2answers
How do I use the SanDisk adaptor and the SanDisk 2GB microSD
The micro card (the smaller one) can be used alone in a port that accepts (microSD ports)such as those on a Sansa c240, c250, e250 etc.
If you have a regular SD slot (larger than microSD) then you plug the micro card in the adapter and plug the whole into a regular SD slot.
Plug the card in your computer and copy paste the files. Or plug the micro card in an MP3 player that accepts it and use you music transfert software.
You only have one card (the micro SD one), which you can use in two possible slots.
Hope it helps.
1helpful
Music
buy a memory card its a MicroSD and a memory card player and download it with music and plug it in ur mobile then turn the music player in ur phone on and u will enjoy the music.
u need two things to complete this task
1/ MicroSd try a Kingston model that comes with 2GB so u can store it witha lot of music that u like!^^
2/u need to got aq memory card player and a computer^^
well if this Fixe ur problem rate me as fix ya hehe
I have an i880 and i am trying to download music from my computer to my phone
You can only add music to the MicroSD card included with your phone. You will need to use the included MicroSD to SD adapter and an SD card reader. When plugged into the computer, the card will show up as a removable drive under "My Computer".
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
