Question about Maytag Atlantis MDE7400AY Electric Dryer
Cleaning lint from dryer vent
How do we remove the screen on the inside front of the dryer? We removed the three screws that appeared to be holding it on, but it still will not come out. Is there a way to remove it?
  • FstEti Sep 27, 2008
    I believe the question has to do not with the actual lint screen that easily is removed but for the screen that is attached to the drum; removing this screen would seem to allow someone to get a vacuum hose into the bottom of the machine to clean up lint laying there. There are three screws holding this screen in and I removed them but the screen still will not budge.
To get to the dreyer vent you need to remove the coplete front and door to get at the vent housing. Even then you still cannot adaquately get inside the housing to clean it.
Posted on Aug 09, 2008
    Problem Solver:
  • 8 Answers
Perhaps I'm crazy, or you are crazy...or I'm unaware of such a thing....but I have never encountered a dryer that required the user to remove any screws to remove the lint screen.
Posted on Jul 28, 2008
HOW DOES THE FRONT PANEL REMOVE -FOR CLEANING THE BURNER AND MOTOR
For the model dryer you have listed, the dryer cabinet can be removed for cleaning by following these steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior.
Once you have completed your inspection and cleaning of the dryer interior re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assistant may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run.
Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them.
If you have any questions about this repair, or if the model number is different, please post back and let me know. I hope this helps you.
Apr 18, 2011 | Roper RGS7646KQ Gas Dryer
I would like to check my dryer for lint. How do I open the top of the dryer so I can vaccum it out if neccessary.
If the model number you listed this question under is correct, access to the dryer interior to clean can be obtained by following these steps:
Oct 21, 2010 | Whirlpool LER4634J Electric Dryer
Dryer get scorching hot immediately. The blower side is cool and we have removed all the lint from the dryer. Any ideas?
you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and if the vent line is long i use a leaf blower to blow out the line.if the filter is on top,unplug the dryer first before you touch it,pull out the filter and remove the two phillips screws in front of it,then remove the vent line and take off the back panel.on the left side you'll see the duct that the filter slides into,remove the 4 screws that hold in on and remove it and clean it out,go outside and make sure the vent is clear,if there's a cage or a screen on it remove it and throw it away,blow out the vent line,next pop the top panel up with a screw driver,there are 2 clips one on each side that holds the top to the front panel around 2 inches from each side in the front,put the screw driver in between the panels and pop it up,on the right side there's a wire harness,pull it apart,it's easier to stick a screw driver in the holder to separate the harness,then there are 2 5/16 inch screws one on each side around 3 inches down from the top,remove them and pull up on the front panel and remove it,vac out the inside of dryer,if you have a shop vac blow all the lint off of the motor and you can blow all the lint and dust forwards so you don't have to remove the drum,some people have trouble putting the belt back on when the drum's removed.do this once a year and you won't have any fires and you won't pop any thermostats or thermal fuses in the dryer.let me know how you make out.one guy wrote back and said he had a birds nest in the vent line and the leaf blower cleaned it all out
May 11, 2010 | Kenmore 63942 Dryer
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
I have Whirlpool Duet Dryer that has a noise.
It is common for small items (such as coins) to get stuck inside the dryer drum baffles. You can easily remove them without disassembling the entire dryer. The screws that hold them in place are located on the outside of the dryer drum. In order to access, follow these steps:
1. Unplug the dryer.
2. Remove the top panel of the dryer by removing the three screws located in the back of the dryer holding the panel in place. Once the screws are removed, the top panel slides back, then lifts off.
Each drum baffle has two screws holding it in place. Remove the screws and the baffle will drop into the drum allowing you to easily check inside each one.
Another source of dryer noise is something caught in the blower fan housing. You will need to remove the lower toe panel directly below the dryer door to access. Follow these steps:
1. Open the dryer door and remove the lint screen (the blower fan cover will not come off with the lint screen in place).
2. Locate the screws that hold the toe panel in place along the bottom front edge of the panel. HINT: Propping the front feet of the dryer up can give you better access to reach the screws (a 2x4 works well for this). With the screws removed the toe panel will drop down, then come off.
3. Remove the screws that hold the blower fan cover in place.
Inspect the blower fan housing for any objects that may be vibrating against the fan blades.
If you still need further assistance, please let me know. I hope you find this helpful.
Sep 01, 2009 | Dryers
Cleaning lint
Your Roper dryer is made by Whirlpool, there is no reason to clean lint from around the heater, very little lint collects in that area. Every once in a while you can take the front off by removing 2 screws from under the lint screen, then pry up the top and there are 2 screws that hold the front on inside facing out. After removing the front you can vacuum inside below the drum.
Jan 18, 2009 | Roper REX4634KQ Electric Dryer
Something in vent
id screen is on top remove the 2 screws under screen lid remove back cover ..remove the 4 screws holding bottom portion of screen housing over blower pull out and clean ..if screen is in door remove bottom cover (clips top edge press down) remove lint screen remove 2 or 3 screws holding housing to blower
Nov 26, 2008 | Kenmore 62802 Electric Dryer
How to remove the back
Dryer back does not come off, the screws removed secure parts to the inside of the case.
put them back before anything detaches.
the front panel comes off
  • pull wall plug
  • remove lint screen
  • remove 2 screws in housing under lint screen
  • with putty knife or other blunt blade in gap between top and front,
    depress spring catches at both corners of top panel front, tilt up top
  • remove 1screw each side 1/3 down front panel
  • remove door swicth wires
  • tilt front panel down and remove
all internal parts are accessible
perform repair
examine rear of case from inside and refit anything detached by screw removal
reassemble in reverse order
Oct 20, 2008 | Whirlpool LER4634J Electric Dryer
I want to know how to remove the lint trap (not just the screen but the entire assembly) from a Maytag Performa PYET344AZW front loading electric dryer. The lint screen will not even properly slide back...
Besides drying clothes, dryers also remove lint. This fine, fuzzy material can cause trouble because it blocks dryer lint traps, clogs vents, and fills blowers. Lint can also gather around and in the tracks of the drum rollers, or in and under the pulleys and the drive belt. The result is poor clothes drying or -- sometimes -- no drying. To avoid lint problems, clean out the dryer's lint trap system every time you use the dryer.
To clean the lint screen, remove it from the unit. The screen may be located near or under the door sill, or in the top of the dryer near the control panel. It can usually be removed by pulling it up and out of its housing. Remove the accumulated lint to clear the screen; then replace the screen.
The exhaust vent also collects lint. Vent maintenance involves cleaning the lint from a screen in the dryer's vent exhaust collar and/or at the end of the exhaust vent where it sticks out through a basement window or through an exterior wall. To clean the screen, remove the clamp that holds the vent to the collar, or back out the screws that hold the vent to the collar, or pull the vent straight off an extended collar. Clean the screen thoroughly and replace it in the vent assembly.
To clean the vent itself, use a vent-cleaning brush (available at hardware stores) to pull out any lint deposits. Also check the vent run to make sure that the vent piping or tubing isn't loose at the joints, or -- in the case of flexible plastic venting -- isn't sagging between hanging brackets. Breaks or sags cause undue strain on the dryer's blower system, and can cause drying problems. If the vent pipe or tubing has become clogged with lint, remove the lint by pushing a garden hose or a drain-and-trap auger through the vent to a convenient joint. Disassemble the joint to remove the debris. With this procedure, it isn't necessary to disassemble the entire vent to find the blockage.You can head off problems before they become too serious by providing routine maintenance for your dryer's door gasket, thermostat, timer, and other frequently used parts. Let's discuss how to service these important components in the next section.
how-to-repair-a-dryer-1.jpgTHANK U.. RATE IT...
Sep 11, 2008 | Dryers
Maytag Atlantis MDE7400AY Electric Dryer Logo
219 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
