Question about Garmin zumo 550 GPS Receiver
Garmin zumo 550 vehicle file
Thanks for your previous fix. I still cannot download vehicles to my zumo. Any other suggestions?
  • Anonymous Mar 29, 2014
    headset showing *** phone
  • 4 Answers
Instructions taken directly from the Garmin website
How to Install:
  1. Connect your Garmin GPS device to your computer.
  2. Click Download.
  3. Click Open, if necessary.
  4. Click Extract.
  5. Browse to find the “Garmin/vehicle” folder on the Garmin drive. You may need to create the vehicle folder.
  6. Double-click the Unplug or Eject icon in your system tray. Click Stop, and then click OK.
  7. Unplug the USB cable from your Garmin GPS device.
Posted on Feb 14, 2009
Zumo 550 User Guide
You can find the different user guides for this unit (in different languages too) to download on this page: https://buy.garmin.com/shop/store/manual.jsp?product=010-00567-00&cID=135&pID=414
Jun 13, 2009 | Garmin zumo 550 GPS Receiver
Import *.gdb route file in Garmin Zumo 550
Import to pc or to garmin device? There is some info in the manual, however you will need an SD card to work with triplogs.
Jul 16, 2008 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 AC adapter inop
Take the unit back for warranty service. If you are using the original adabtor it should work. Take note that the Garmin GPS's are designed to work only with original Garmin accessories.
Jerry G.
Jun 24, 2008 | Garmin zumo 550 GPS Receiver
Lost my vehicles
Go to http://www8.garmin.com/products/webupdater/howtoinstall.jsp, select download webupdater, choose run(install) instead of save, run the webupdater to check if your device needs updates like firmware, bluetooth, gps....after that you'll find a whole lot of language and text stuff (pick the ones you need only) and a bunch of vehicles....I don't think it comes any easier....
Jun 23, 2008 | Garmin zumo 550 GPS Receiver
Zumo 550 blanks out
Is the GPS in the cradle? How is it wired for power? Any SD cards in the GPS? If so remove that first.
Sometimes line-noise can cause eratic behaviour, line-noise usually comes from the generator, fans, ignition systems. try to wire the device closest to the battery, the battery works as a capacitor and reduces line noise. Try and run the gps with the wall charger, does it happen then too? Make sure you are on the latest firmware (garmins webupdater) .If it works okay running off the wall charger, then check what's with the vehicle power supply. Nothing there, insert the sd card....as soon as problems start, check the last changes made
Jun 15, 2008 | Garmin zumo 550 GPS Receiver
No road maps ( Zumo 550
Do you see a map, with street detail? Any SD card installed?
Tap the wrench symbol, tap mapping, tap about, any maps checked? if not, check the apropriate map and go back to the map screen
Jun 07, 2008 | Garmin zumo 550 GPS Receiver
Connection problem between a nokia n95 8gb and zumo 550
I have recently purchased a Zumo 550 and successfully copied across selected phone book entries from a Nokia N95 without the need to use any additional apps:-
1) Assuming the N95 and Zumo are paired via BlueTooth
2) In N95 Contacts - use 'Mark' / 'Mark All' as necessary to select the contact entries you wish to transfer to the Zumo 550
3) In N95 Contacts - select 'Options' then 'Send Business Card' then 'Via Bluetooth'
4) Select the Zumo 550 device from the list of paired Bluetooth devices
5) Contact data is transferred from N95 phonebook to Zumo 550 phonebook
Interestingly, Garmin don't seem to list the Nokia N95 as being a supported device on their website, but the above process worked for me!!
Feb 15, 2008 | Garmin zumo 550 GPS Receiver
Fitting zumo 550 to ducati st4s
RAM mount (http://www.ram-mount.com/gps_mounts/model_garmin_gps_mount.htm)
Dec 09, 2007 | Garmin zumo 550 GPS Receiver
Transfer Problems
I locked my garmin zumo 550 and forgot the passcode
Oct 11, 2007 | Garmin zumo 550 GPS Receiver
Zumo 550
Go to the garmin website download webupdater, use this to figure out what files it needs, and select the apropriate sound files, web updater will download and install them for you!
Aug 13, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
202 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
