Question about Acer Computers & Internet
My acer 5520 LCD screen remains black even though the DR and everything else remains functional.
    Problem Solver:
  • 9 Answers
If you have a video adapter, try plugging it there. maybe you just plug it to the built in video adapter instead of your PCI video adapter.
Posted on Jul 28, 2008
My laptop screen shows black even though laptop is able to power up.. What does this mean?
The backlight on the monitor might be burnt out, hook up the computer to an external monitor just to rule out the computer itself. If it is burnt out then the only option would be to send it in for repair.
Sep 23, 2011 | Acer Aspire 5520-5908 Notebook
Hi, I have acer aspire 5520,2 Gb RAM... When I turn on my acer,everithing works just fine,exept monitor,it remains black,When I try ecternal monitor,it works fine,windows wors fine to,everithing but the...
Aspire 5520 has LCD Display. The screen displays becomes dark/ dim if there is no backlight.
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Inverter board, which provides high voltage to the CCFL. These parts are inside the LCD screen. Either of the parts may be faulty or in some rare cases both. Also, the video data cable may be loose or faulty, which can be identified only after opening the top cover.
So, my advice is that you get it properly checked by any professional for replacement of Inverter or CCFL.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 22, 2011 | Acer Aspire 5520-5579 Notebook
I have an acer 5520g, the screen remains black, have tried fn f4, takentn battery out held power button down, still nothing anyideas please?
if the computer seems to be booting you might have a bad lcd back light what you can do to check is hook up a external monitor to the unit,
let me know if you have questions
Oct 02, 2010 | Acer Aspire 5520-5156 Laptop
ACER screen goes black after a few minutes of being on. I then close the laptop then log on again and the screen comes on then flickers off back to black, can very faintly see the desktop in the back...
Hi. This might be an LCD issue or connector inside th LCD from the motherboard is loose. You may try troubleshooting the issue first before you send the computer for repair. This process will drain the remain electrostatic energy to your motherboard which sometime causing the issue. Please follow troubleshooting steps below.
Take out the battery and unplugged the power adapter
Press and hold the pwoer buttong for 30 secs
Put everything back in
Power ON the computer
have a good one!
Jul 29, 2010 | Aspire Acer 7520-5071 Notebook
I have an Acer Travelmate 5520. Last night while working the screen started to flash and then went totally blank. I powered down and back up again and the same thing happened. The laptop is running but the...
Most likely the inverter module for the lcd screen has failed. If you can hook up your laptop to an external monitor, you will be able to make sure that the rest of the laptop sill functions.
An inverter is a inexpensive part, $10-15 dollars, but requires that the lid be disassembled somewhat to install it
Oct 21, 2009 | Acer TravelMate 5520 Notebook
Can't turn my lappy on
Damaged Bootstrap You need to take it for repair
Aug 16, 2009 | Acer Aspire 5520-5908 Notebook
Acer travelmate 5520, when you start is white screen after 20 seconds and stops
Test the laptop with a external monitor see if you get any picture on the external if the external screen remains white then most likely the mainboard or the video adapter (in most cases build into the mainboard) is failing or has failed. One Possible reason could be overheating damage (the unit may not be overheating right now during the 20 seconds, it may have suffered earlier).
It could also be a poor connection between the display and the mainboard. but if the screen works for 20 seconds and then goes white its probably not the issue.
If the external screen works without any problems the issue is most likely your lcd screen or one of the boards inside.
If you are in warranty get in touch with your dealer or acer.
If you are outside of warranty get in touch with acer or a local repairer / acer cervice center.
Thanks,
Ekse
Aug 14, 2009 | Acer TravelMate 5520-5678 Notebook
Camera screen remains black when I turn on shooting mode
Turn the camera on. With the screen showing, press the DISP button and this will give you a selection of different screen views i.e. squares for aligning shot squarely; black - thru viewfinder only; etc. Different modes will give you different screen displays i.e. P setting screens are different to when you have the camera set on AUTO.
Hope this helps.
Jan 11, 2009 | Canon PowerShot S51S Digital Camera
My screen is almost black
Generally in such cases , the screen is always at fault. The LCD lamp goes out and thats the reason the screen is dim. If the system is still under warranty get the same replaced.
The other thing you can do is to Reseat the LCD cable to the motherboard. if the same is not connected properly it can result in the same scenario.
Thanks
Proton
Jul 26, 2008 | Acer Aspire 5520-5908 Notebook
Computers & Internet Logo
93 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
