Question about Cameras
Olympus zoom camera ED lens #sp51ouz
Error message says, zoom error and the lens won't retract. The camera won't take a picture but you can look at pictures already taken
  • 31 Answers
It seems that the moter or track is either damaged or out of line this will need to be fixed by an engineer sorry
Posted on Jul 28, 2008
Press power button nothing happens
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 27, 2011 | Olympus Cameras
Zoom Error message
The problem you are describing is a problem with a sensor in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $167.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 23, 2009 | Olympus SP-550 UZ Digital Camera
Lens does not zoom in
This is not a common error on canon digital. This is caused due to possible short in zoom control circuit (main pcb). At normal use, if the lens does not retract due to mechanical jam, when the zoom control button is pressed, lens error 18 message supposed to be displayed. Since control circuit is shorted and faulty, error 18 message was not displayed. The remedy for this problem probably requires a replacement of a main pcb. Replacing a main circuit board may run around $100-140. -James
Mar 29, 2009 | Canon PowerShot A640 Digital Camera
I have an Olympus SP 320 camera, zoom error comes up and it shuts off
I just pulled my 320 out after not using it for 4 months and the lens extended and zoom error began flashing on the screen. After reading a few other post on the net about how much it cost I decided the camera was a goner. For good measure I banged it on my mouse pad a couple times and the lens suddenly retracted and it is now working fine. Doubt it will work very often but might be worth a try. Make sure you hit it on something soft to prevent other damage.
Sep 15, 2008 | Olympus SP-320 Digital Camera
Olympus 8080 C 8080 wide zoom
It may have jumped a tooth, something like a car timing chain. The Zoom in this camera is a barrel that has 3 cams that rides inside another barrel that has "tracks" for the cams. The motor rotates the the outer barrel via gear teeth, forcing the inner barrel to extend or retract. There is a tab on the gear teeth that might index the position of the zoom lens. If this tab is in the wrong position, if the gear jumped a few teeth, the camera may not know where the zoom lens is in relation to the inner focusing lens, and cause the "zoom error" If that is the case, I can help you get it back into position. This is a theory, but does explain the tab on the gear and the constant zooming.
May 27, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Zoom Lens doesn't Zoom
Check you haven't accidentally got the camera into some fixed-zoom mode ("Super-Macro" is a favourite for this on Olympus cameras).
A.
Apr 06, 2008 | Olympus Camedia C-765 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
Mar 03, 2008 | Olympus SP-550 UZ Digital Camera
Zoom lens Motor Problem?
The suggests the zoom control failure
Only Olympus can fix it to it will have to go back.
Nov 08, 2007 | Olympus Camedia C-740 Ultra Zoom Digital...
Cameras Logo
188 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
