Question about Whirlpool GD5SHAX Side by Side Refrigerator
Whirlpool Gold Refrigerator
Why is the strip where to two doors rest is very hot?
GD5SHAXLT01
SM 354408
Type 25SSA
  • 218 Answers
When this area gets very hot, it's usually because of inadequate air flow across the condenser coils under the refrigerator. Check to see if the condenser fan has stopped blowing underneath. Remove any obstructions or replace the fan motor if it has stopped. Also clean any accumulation of dust from the coils. The refrigerant line runs down the divider at the front of the unit to warm it slightly and prevent condensation and/or frost there, but it should not be noticeably hot.
Posted on Jul 28, 2008
Hi. I have a side by side refrigerator made by whirlpool. It's ED5NHEXNBOO, Type 25SSA. Do you have any info on that?
what kind of info? if you're looking for an owners manual you can go to Whirlpool.com and you can download most manuals.
May 22, 2010 | Refrigerators
Why wouldthe center piece between freezer & refrigerator get hot
There is a heater located behind that strip known as the mullion heater.
Look to see if you have a switch labeled "anti-sweat"
Apr 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
My refrigerator Door (Whirlpool Gold)does not close like it shoul
You need to bend the door, if the gap is at the top put your foot between the frig door and the bottom and push the door closed slightly. so you can check it and do a small amount at a time. till tou reach the point that the door closes tight. if the gap is at the bottom put a shoe or something about 4 to 5 inches wide. go for it you can fix this..... saw
Dec 05, 2009 | Washing Machines
The panel between the freezer and refrigerator heats up - too hot to touch for a while then cools off again. GD5SHAXLT01
You need to clean the coils under the front of the refrig of dust , lint , pet hair , etc . Pull the refrig out and remove the back panel covering the compressor . Make sure the fan there , next to the compressor is working . Usually , if this fan is not working , the center strip gets very hot , and the compressor may cut off , from getting too hot . The compressor can burn out , if the fan doesn't work for a while .
Sep 13, 2009 | Whirlpool ES5FHAXS Side by Side...
Hot strip between doors
the fan by compressor is not running assuming that the rest of the refrig is ok.
Jun 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool side by side front vertical panel is hot. What is my problem?
Clean the condenser coils in the back, or under the fridge. Poor air flow under the ref. will cause this strip to get hot. It should always be a little warm, but not hot.
May 04, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Refrigerator door gasket pulls down and brakes off on top corner
Look it over and see how it is held in place. A stripped screw or bent clamp depending on what holds it in place is the most likely suspect.
A stripped screw get a slightly bigger one or shrink the hole with tooth pics or match stick.
Bent metal strip remove and straighten possibly bending a little more in the opposite direction. And sometime 1 metal strip may be put on upside down or turned around backwards and not holding. look for similarity in the way these type of bracket/strips attach.
If this helps please rate me as high as possible.Thank you for using fixya.
Apr 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GD5SHAX Side by Side Refrigerator Logo
345 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
