Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp lc-c3234u 32" flat screen hdtv turns off and on
I purchased a new Sharp LC-C3234U hdtv yesterday, and it worked great for one day, until it suddenly shut off. It now turns on for about 4 seconds, then shuts off and restarts over and over. I unplugged it and plugged it back in, but same thing. I called support, and they asked me to unplug set, and press the power button for 1 min., then wait 5 min. before plugging back in. It worked again for about 10 mins., then did it again. What's up with that? it's a brand new tv! Please help.
  • 3 more comments
  • 63eagle Oct 03, 2008
    Purchased same LC-3234U from Costco, the on/off problem occurred after two months of bedroom use. Sharp C.S. did nothave a solution, suggested a warranty repair man.
    Exchanged the set at Costco for another one. Same probelm occurred after one day.
  • joeljay1 Nov 05, 2008
    The same problem happened with my set after just a couple of months of use. Costco's concierge service also recommended that one-minute hold of the on/off button. While it worked initially, after about 10 minutes of operation, the tv went back into break-down mode. It was then when I tried something I never would have thought of trying, it was just a spur of the moment thing.
    I simply disconnected the component cable from the tv and turned on the tv. It turned on and stayed on. I then plugged in the component cable on a different input (from input 1 to input 3). I've operated the unit for a couple hours now without any incident. I'd recommend you try the same thing and see if it works.
  • Anonymous Nov 16, 2008
    The same thing...but kind of different. My sharp tv from costco has never turned off. It just has a hard time starting, i have to press the on button about 4 times, it goes thru its starting cycle, but finally will come on. The tv always stays on, and the picture is the best picture i have seen in HDTV
    i am using component inputs to the #1 input. 32" sharp aquos lc-c3234u
  • Anonymous Jan 22, 2009
    not the same problem but the remote sensor on the same model from costco goes out and in....purchased less then a month ago....returning asap for a Vizio 37"
  • Anonymous Feb 19, 2009
    Same thing here.Tried everything and still shutting on and off by itself.
Firmware sharp lc-c3234u
Do you have the necessary equipment to install it?
Aug 25, 2014 | Sharp Aquos Televison & Video
I have a Sharp Aquos LC-C3234U TV. I can turn it on and than the screen goes black but the volume is fine. What can I do to fix it?
Check its back-light inverter board, and the voltage comes to it from the main power regulator board. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 03, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I hav an LC AQUOS TV Model Number LC-C3234U..The power button keeps going off and blinking green..tried holding power button down but it comes on yellow and then goes to sleep blinking green again..wh
These blinks are fault indications. Count the number of blinks occurs at one time switch on, and check this link for details. The link contains the blinking codes to many brand TVs.
Jan 29, 2013 | Sharp Aquos LC-C3234U 32 in. LCD TV
I have a sharp Aquas model # lc-c3234u when i try to turn on the tv it will only stay on as long as I hold the power button down serial # 806-884921
U mean the manual buttons on the tv itself?Yes,than the tv maunual controls function board is shorted and dead.Tries websites like Shopjimmy.com,Ebay.com to buy a manual controls buttons board for the replacement.
Feb 25, 2011 | Sharp Aquos LC-C3234U 32 in. LCD TV
Sharp Aquos LC C3234U screen goes black, audio is still good, turn to another channel far away from the intended channel & it will reset. More often as time goes on.
Ur LCD inverter board it dead,replaced this LCD inverter board will get ur picture back.It long board in shape.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.
Mar 31, 2010 | Sharp Aquos LC-C3234U 32 in. LCD TV
I have a Sharp 32 inch LCD TV (LC-C3234U)that sits
Try the head phone jack there are some kool remote systems out that support the head phone output.
you can also place them anywhere in the room.
Mar 24, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
2,311 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
