Question about Vacuums
Miele vacuum Sometimes when I hit the auto roll up cord button or even move the cord, the power vacuum goes off. I move the cord again and it comes back on. I took it apart and looked at the connection from the cord to the auto roller. These are the electrical slip on type connections and are still in good shape. There are no bends in the cord. I air dusted everthing inside, put it together (with no extra parts!). Good powered up so I did not break it, but it still has the same problem. What should I do next?
  • austin571 Jul 30, 2008
    Tried to take it apart so I could replace the cord, then I heard the metal stip unravell. Don't know what it was connected to to put it back together. Thought I had it, but the button to push down to roll the cord did not do anything. Still stuck, but even more problems now.
  • austin571 Aug 02, 2008
    Thanks ol_lonely - it worked. I had to go to Radio Shack to get the small connectors, but total fix was 2 bucks!
Why won't my Miele 8310 vacuum switch on?
The problem could be a restriction in the brush roll somewhere. Remove the brush roll and clean it and the nozzle housing. It could be an electronic problem which is much harder to diagnose.
Apr 10, 2016 | Miele Vacuums
My Miele S4780 Vaccum has no power at either the switch on the unit or the hand held nozzle. I checked the cord and it seems to be OK. What could the problem be?
Could be the cord reel. Try laying the vac on it's side and turning it on. Sometimes you may even need to gently bounce it. If this works, you have a bad cord reel. Check my other answers for how to fix this.
Aug 04, 2014 | Miele Vacuums
S5830 canister vacuum
Do you mean S5380?
Phone local vacuum repairers and ask for estimates. The power cord is only fairly cheap. I would have thought that even with expensive labour it should cost less than 100$. He's probably trying to cover himself in case its something else. Have you contacted Miele? it is worth asking for a price if they'll give you one
Miele Inc Anything Else is Compromise
As far as replacing the cord yourself, it's not as simple as just connecting it, i think it has to be put on a tensioned drum.
Heres some more info
How to Access the Motor and Cord Retract on Miele S326
Miele vacuum cleaner repair
May 20, 2014 | Miele Vacuums
I have a Miele Solaris that is having an intermittent power problem. The power will not turn on unless I push the cord winder button at the same time as the power button. I have disassembled the vacuum and...
These type of cord retractors have a set of contacts which sometimes get corroded or bent. Or maybe the reel has become wobbly.
As the cord reel moves, these contacts should have enough pressure stay in contact with the tracks on the reel at all times.
You sound like a handy person, so you would have to take the assembly right out of the machine and perhaps be able to correct the situation.
Some of these contacts are easily accessible, and others not so easily.
While you have the old assembly out anyway, you also might be able to buy a new one to replace it.
Without a close look it's hard to guess what to advise you.
Maybe a vac repair shop could throw in an tune up as well?
Check the motor brushes and so on?
Jun 17, 2011 | Vacuums
The mechanism that rolls back in the power cord seems to be working slower and sometimes not at all. Was wondering if the mechanism in question has an adjustment to increase the tension on it so the power...
it easy to adjust the roll back of vacuums the problem is hard to dismantle the unit to remove all the things to see the adjustment roll,all vacuums is need to remove all screw to open the unit even to replace the small parts like switch,and sometimes we cannot adjust the roll back if the spring is worn out we need to replace the new one,for me much better call and service technician for your comfortable and practically to not damage the other plastic part of the unit.and you get a warranty service for that one.
Jan 01, 2011 | Kenmore Vacuums
Meile red star
Yes, this very well could be a problem with the cord reel, especially if it happened all of a sudden. There's a few ways that you can diagnosis this problem yourself. First make sure the cord is all the way reeled into the vacuum. Next find an outlet that's close, and only pull out enough cord as you have to, to be able to reach the wall outlet. After you've plugged the machine into the wall, use one hand to slowly pull more cord out of the vacuum, and use the other hand to continuously turn on and off the vacuum pushing the foot pedal that controls the main switch. Slowly pull the cord out, and turn the vacuum on and off, on and off, on and off.
At any point while you were doing this did the vacuum come on, even for a very short time? Did it even make a noise like it was trying to start? If you heard a noise, or the vacuum even came on for a time, then this definitely indicates that you have a bad cord reel.
If it didn't make a noise or come on, you still may have a cord reel problem, but you'll need to take the machine apart to further diagnosis it at this point. A simple continuity electrical tester will be needed to test the cord reel.
Here's a very detailed repair instruction that I left for a similar model Miele on Fixya already. The model that you posted the repair under is a Miele Red Star which is an S314i, the model I repaired the cord on was actually a S514. The cord repair on both of these models is identical however, except your Red Star actually has two screws that need to be removed from the variable speed control box, the S514 only has one. Otherwise, it's almost completely the same repair. If you need to purchase a cord reel for your Miele, here's a direct link to the Miele S300 series cord reel that goes with your Red Star:
Even better, if you purchase the cord reel from GoVacuum, you have 60 days after the purchase that you may return the cord reel to us if that wasn't the problem (we do test all the returns to make sure that they weren't damaged when being installed), and as long as the cord reel is returned undamaged, we give you a full refund, we don't believe in restocking or shipping fees. Better yet, we even include a return label with every order that you may use for free to avoid return shipping charges.
If you find that the cord reel is not the problem, that can only leave one of three things; the switch, the motor, or the pc control board that's on your motor. In 10 years of fixing Miele vacuums however, I can safely bet that it's your cord reel.
Anyways, here's the link to step by step instructions on how you can remove the cord to test it, as well as replacing it. If you have any questions, please feel free to use the Clarification or comment form here on Fixya, or contact us by phone. If this was helpful to you, please be so kind and rate my repair as helpful by clicking the thumbs up icons at the top of the page. Thanks so much!
How to Test & Change a Miele Cord Reel:
Chris J.
Apr 06, 2010 | Miele Red Star Bagged Canister Vacuum
I just bought a Miele s558 Silver Moon, seems like it's from 2000 or so. If it's in good condition, can I expect this machine to last another ten years? Or would it have been better to buy a lower end...
Greetings from GoVacuum,
Ahh, the Miele Silver Moon model S558i. This is great model that I know a lot about because I actually own this exact model. I have had my Silver Moon now for going on 10 years, with almost no problems. The motors in the Silver Moons are excellent, and should last 20 or 25 years without problems. This particular model did have one major problem however. This is the first model that Miele put the suction controls in the handle of the hose of the vacuum, allowing the user to easily adjust the suction setting with fingertip controls. The problem with these models is that static electricity (usually happens when vacuum carpeting) causes the hose to shut down the power to off. You can be in the middle of vacuuming, and all of a sudden the vacuum will turn off. You can easily turn back on the vacuum with the push of a button, but it's irratating for sure.
Miele did come up with a solution for this problem with a newly redesigned hose, part number SES125-3. Since this new design has come out I haven't had a single issue with my hose. The way you can tell if you have the old or new hose is by the numbers (or lack of ) on the different suction levels. If your hose goes up to 1100 Watts, then this is the older style hose. If you're hose simply has a minimum to high setting with no numbers at all on the hose, then this is the redesigned 125-3 hose.
If you have the older style hose, I would get the dealer that sold you the vacuum to exchange the old hose for the new hose, you definitely don't want to have to buy that new hose ($150+). If you have the new hose, then I would say stick with the Silver Moon over the newer Miele models, in my opinion the Silver Moon is one of the most durable models that Miele has ever made.
The only other thing you need to be careful of is the cord reel. When you are retracting the cord reel, it's best to kind of guide the cord back in, and take it slow rather then just stepping on the cord rewind pedal. The cord reel can sometimes be touchy, especially if you are rough with it. If you're careful with it, you should never have any problem with the vacuum cleaner as long as you change the filters on a regular basis as well as the bags.
I hope this helps, if you have any further questions, please feel free to contact me at chris (dot) jones (at) govacuum (dot) com.
Thank you,
Chris Jones
Mar 18, 2010 | Miele s558 Silver Moon Vacuum
Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
Oct 07, 2009 | Miele S558 Red Velvet Bagged Canister...
Miele Blue Moon vacuum has no power
It can be various problems, the cord reel contacts or cord may be bad, You didn't give the model number, but alot of Miele's have a speed control that goes bad. It will have to taken aprt and checked.
Jan 31, 2008 | Miele Blue Moon Bagged Canister Vacuum
Vacuums Logo
77 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
