Question about Insignia IS-PDVD10 Portable DVD Player
Etched ring on outer ring of dvd disc
Salutations Experts.  My IS PDVD10 is making a ring around any dvd disc.  The cushion or padding that I guess supports the disc is having uneven wear on by closely examining it.  There are a total of 6 pads. They look uneven and some are flatten.  Is that my cause?  Can I fix it or replace those padding? if that is the cause. JS
  • jtsing000 Aug 02, 2008
    Thanks for the help.  I finally found a felt with a sticky back and the close to the same thickness at Target.  So far No etching...Thanks again
    Novelist:
  • 170 Answers
Hey jtsing000,
Yes you can replace these pads with felt pads. You should be able to purchase some adherable pads for furniture legs at Home Depot, Menards, Lowes, or any hardware store...just get the really small ones. Otherwise you can cut your own out of felt from a hobby, craft, or fabric store.
Before going through all this trouble, check to make sure your discs are seating completely on the spindle. If you are getting a partial ring, this may be because the disc is not clipped in on the spindle completely. If the ring is all the way around the disc, then there is an issue with the height of the spindle.
I hope this helps!
Posted on Jul 29, 2008
It keeps saying no disc
If you are trying store bought discs and more than 2 are not playing, and all of the discs are clean of smudges then the issue is the dvd reader in the player. The unit will need to be replaced/repaired. Repair however is usually more expensive if not just as expensive as replacing the unit.
May 07, 2010 | Insignia IS-PDVD10 Portable DVD Player
How to insall front brake pads on a 2000 Ford Focus
caliper bolts are 7 mm Torx head.
SECTION 206-03: Front Disc Brake 2000 Focus Workshop Manual
REMOVAL AND INSTALLATION Brake Pads Removal
syy~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: If brake fluid is spilt on the paintwork, the affected area must be immediately washed down with cold water.
  1. Loosen the wheel nuts.
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the wheel.
  1. Detach the brake hose from the support bracket.
  1. Detach the outer brake pad retaining clip.
  1. NOTE: Pull the caliper outwards to release the piston.
    Detach the caliper.
    1. Remove the bolt covers.
    1. Remove the bolts.
  1. syy~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Suspend the caliper to prevent load being placed on the brake hose.
    Support the brake calipers.
  1. Lift the outer pad retaining clip over the spring retaining lugs.
  1. Remove the outer brake pad.
  1. Remove the inner brake pad.
Installation
  1. syy~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: If the caliper piston is retracted into the housing, brake fluid will be displaced from the master cylinder.
    Fully retract the caliper piston.
  1. syy~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure the brake disc faces are clean before installation.
    Install the inner brake pad.
    Install the outer brake pad.
  1. Push the outer retaining clip over the spring retaining lugs.
  1. Install the caliper.
    1. Install the bolts.
    1. Install the bolt covers.
  1. Install the brake hose onto the support bracket.
  1. Locate the outer pad retaining clip.
  1. Install the wheels.
  1. Check the fluid level in the brake fluid reservoir.
Jan 18, 2010 | 2000 Ford Focus
No disc fault appears on screen of model insignia ns-pdvd10. Am I able to correct this problem?
Ensure that the disk is clean. The player may not play a disk if there is internal condensation; leave the player on for an hour. You may wish to try a lens cleaner. If these steps don't resolve the problem, repairs may be required. Service can be obtained by carrying the unit in to the place of purchase.
Dec 25, 2009 | Insignia NS-PDVD10 Portable DVD Player
Front drivers side disc brake on 2001 dodge stratus. put on new rotor and brake pads. Get up to around 5mph it makes a noise, until brakes are hit. accelerate the noise starts again. outer brake pad is...
The piston from the caliber will keep the inner and outer pads close to the rotor. If outer pads is loose, need to reassemble to find out if it didn't get installed right.
Nov 01, 2009 | 2001 Dodge Stratus
I have Insignia PDVD10 portable DVD player. So
Press remote button audio track. That solve my problem.
Jul 04, 2009 | Insignia NS-PDVD10 Portable DVD Player
Scratching disks
Microsoft have changed the mould for the dvd trays (or the suppliers have changed them at least) so that on the latest editions of the 360 it does not scratch them as much as it used to. the previous person is right. what happens is that when the disc is being read from it will spin very very fast and one slight knock on the older 360's would produce a ring right around the 360. this happens when the game disc wobbles and touches the moulding on the dvd tray.
i would try not to move the console while its on, wait at least 30 seconds before moving the console after you turn it off.
if you have a wired pad this can make things worse as everything you pull the pad it can make the disc wobble and cause this problem.
a friend of min stopped this happening by getting a thin enough peice of soft foam and gluing it onto the tray so that when the discs did wobble they would skim the soft rubber and not the hard mouldings.
im also guessing its a samsung drive you have because the earlier ones were really bad for this.
hope it helps a bit.
www.fixmyconsole.co.uk
Jan 30, 2009 | Microsoft Xbox 360 Console
Keeps saying "No disc" when I put a DVD in to play
This sounds like the lens inside the unit is broken. Take it back to where you bought it from they should take it back under warrenty.
Jan 08, 2009 | Insignia IS-PDVD10 Portable DVD Player
Rings around the disc
It's caused by badly pressed discs - due to shake caused by the high speeds of the disc spinning and then catching the laser assembly. There are things you can do such as place foam pads inside the DVD drive itself, so discs cannot move as much when they spin.
Jul 18, 2008 | Microsoft Xbox 360 Console
Insignia IS-PDVD10 Portable DVD Player Logo
60 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
