Question about Olympus Cameras
Camera indicates "zoom error". You can look at pictures already taken but can't take anymore. AND we are in Hawaii
  • 6,487 Answers
That can happen in zoom point and shoots with longer focal lengths. What has happened essentially is that the lens gets stuck having become out of alignment. Often when the lens is out but it can heppen when the lens is in as well. The camera then refuses to move either to focus the lens or to retract when powered off. It often happens when the camera is struck or dropped.
If your camera is still under warranty, the best thing you can do have them fix it.
If your camera is out of warranty, the one thing you can try is to If you gently, and I do mean GENTLY push against the lens with the PALM of your hand as you turn it on, it may cause it to depress back into the camera. If that doesn't work, and you can't reset it or turn it on/off several times, then you may have to send it in for a repair estimate anyway.
Hope that helps........
Posted on Jul 28, 2008
  • Olympus Master
  • 13,433 Answers
Zoom error indicates a problem in the lens mechanism, Its either stuck or there may be sand in there.. Is it extending all out? does it go back in? Sorry but the only solution to this is either to tap it on the side or take it to a professional who can do the cleaning inside or fix broken parts.
How when I zoom on a picture already taken, it want save it , how do I do this
you need to cut the picture with a program like photoshop, gimp or picasa, and then save it with a different name, or you will overwrite the original picture
Aug 31, 2014 | Nikon Coolpix P520 Camera - Silver 18.1Mp,...
Camera won't zoom correctly.
Lens errors (Zoom Errors on FinePix) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Nov 12, 2011 | Fuji FinePix F20 Digital Camera
When I try to see the pictures I have taken it comes up "read error." What should i do?
remove the memory card and plug it again. still not work? try repair your memory from PC (error checking option).
Mar 19, 2011 | Fuji FinePix E900 Zoom Digital Camera
After inserted recharged battery, the LCD screen is blurry. Pictures taken is also blurry. Camera turns off itself when using the " T " zoom button PLS HELP
Make sure you hold the camera steady .It has been my experience that if you hands arent steady your going to get a blurry pictures and also it will look blurry in the LCD window.
Jan 28, 2011 | Olympus Camera Case For Olympus Fe-4030...
My g.e camera always indicates picture error when i try to view
taken photo might have not stored well,memory card/card reader problem so clean chaqwue and adjust.
Mar 16, 2010 | GE A730 Digital Camera
Olympus zoom camera ED lens #sp51ouz
it seems that the moter or track is either damaged or out of line this will need to be fixed by an engineer sorry
Jul 28, 2008 | Cameras
ZOOM ERROR
What just started? The camera? Do you have fully charged batteries? Did you check the manual?
Dec 30, 2007 | Fuji FinePix S7000 Digital Camera
System error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Listed Fix #4 might work for you. Place the camera on its back, and hold the shutter button down while powering on the camera.
Dec 21, 2007 | Nikon Coolpix 3200 Digital Camera
Cyber-shot w50 zoom problems
If this error message appears, turn off the camera and remove the batteries for 30 seconds. Afterwards, reinsert the batteries and turn the camera back on. Perform a manual reset of the camera. Once you perform this it will be back to factory settings and you will lose any pictures stored on your camera.
Aug 26, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Cameras Logo
24 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
