I have a SONY KV-32HV600 and have begun having problems turning the set on. The flashing code blinks seven times each series. I phoned the SONY tech # and they told me that 7 times meant overheating and I checked for dust and made sure that it has sufficient space for ventillation but the problem still occurs. It occurs more often each week. I noticed today that if you continue holding the on/off button down that it will come on. The picture is fine when it does come on. I would like a diagnosis and if a part needs replacing, the part # with instructions detailing where the part is located and how to replace it. My e-mail address is dhayden@cableone.net.
  • Red Hill Jul 28, 2008
    Thanks. Can I check theese parts with an ohm meter? If so am I looking for continuity, resistence or what and how can I identify the part as I do not have a service manual.
    Master:
  • 848 Answers
Check C515 & 516 and the jungle IC, IC206..........
Posted on Jul 28, 2008
  • 19,396 Answers
  • Ginko
    Ginko Jul 28, 2008
    E6 is heating detected with no water present,
    check water supply, valves, kink in hose, check that there is no debris in the hose.
KV-24FS100 TV shutting off
How many times the standby light flashes in between switch ON and going OFF?
For more details about this fault, visit this site, and call older posts.
Type in this link address, [without brackets] either to Google Search Box or into the Address Bar to your browser and press Enter. It has all the details about blinking codes of Sony Sets.
electronicshelponline(.)blogspot(.)com
In name [Electro-Help]
Apr 16, 2012 | Sony FD Trinitron KV-32HV600 32" TV
Sony KV-32HV600 will not turn on. Light blinks then nothing, have left it unplugged for 24 hrs, worked a couple of times but now nothing. Have disconnected it from cable, still nothing. Looked online...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 22, 2017 | Sony FD Trinitron KV-32HV600 32" TV
Our TV has no picture or sound so you don't know if it is on or off and where it says stand by on the front of the TV there is a red light blinking.
The red blinking light is an error code. The number of times it flashes tells the service tech where to look for the problem. You can search online with your model and the number of flashes to find out more information about the code and where the issue is with the TV. You'll also be able to find solutions for repairing it yourself if you are experienced with repairs of this nature. Good luck!
Oct 10, 2010 | Sony FD Trinitron KV-32HV600 32" TV
My Sony Trinitron Kv-32hv600 32'' WONT TURN ON
The signal board is your problem. If under warranty take this to your leader!
Oct 01, 2009 | Televison & Video
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony KV-32HV600 won't turn on.
If the blink repeats the same number of times (up to 6 or 7) between pauses, the number of blinks is a trouble code. Determine that number (count), then search this site and the web for your TV model and that code. Also look on the rear of the set for the chassis number, and search on that keyword.
Sep 15, 2008 | Televison & Video
Tv pops when turned on.
This unit most likely has a number of bad connections inside. The 4 blinks indicate a problem witht he vertical circuit and the 7 are with the horizontal high voltage circuit. I'd try looking for bad solder joints and resoldering them first. Report back if that does not resolve the problem. I suspect that the set will still fail but with only 1 of the listed blink codes. If that is the case, we'll start looking for faulty parts in that circuit.
Dan
Jun 02, 2008 | Sony FD Trinitron KV-32HV600 32" TV
No Video or Sound - Red Stand By Light Blinks 6 Times
My book that i have with my tv says it is time to have it servicedby adealer sorry thats all it says
Nov 06, 2007 | Sony FD Trinitron KV-32HV600 32" TV
Television will not turn on
My Sony KV 32HV600 will not turn on, unless I take it for a car ride THen it will turn on and is fine until it shuts off again. Which circuit board should I change or send in for repairs? definately there is a loose contact as you have ezplained. please check connector or some print loose or parts loose in power supply. if it is ok then check h/output section for loose or print break. it is not a major problem &can fixed ar home. no need to change board remove board &check for print. it requires tech knowledge.
Oct 04, 2007 | Sony FD Trinitron KV-32HV600 32" TV
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
