Dynex DX-LDVD22-10A 22 in. HD-Ready LCD TV Logo
Posted on Feb 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2yr old hit the screen, nothing cracked but the screen has lines straight up the side and across the bottom. It spiders out from the spot where he hit it with something. No cracks, but webbing out from the point of impact
Anonymous
Level 3:
Master:
  • Master 691 Answers
  • Posted on Feb 24, 2011
Anonymous
Master
Level 3:
Master:
Answers
691
Questions
Helped
126522
Points
1740
Yes it's cracked inside and there is no fix for a cracked screen, the panel will cost more than the tv new. It's not worth it, verify at vancebaldwin.com
Cracked screen on lg lcd tv small crack 6in up an 8in from right can still see picture ok but have a 1in white line running down from small impact area and a light grey 1in line across from impact area...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
2helpful
Is there a glass behind the touch pad????My phone has multiple color lines, in one corner of screen, it looks like spider web cracks???don'tt remember dropping or hitting it???????? soem one told me it...
Yes there is glass in a touchpad- the fact that you have spider webs indicated that part of the LCD has cracked- and it could have been at the factory with a small defect that finally broke. I would approach your provider from that angle.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
One of my kids hit the screen with something. when off it looks fine, but when on the screen looks cracked on the inside, plus there is lines of color running side to side and up and down. sometimes theres...
I hate to be the bearer of this news...but the LCD panel is cracked and ruined. Probably will NOT be worth repair. I have one in my garage JUST Like this, only a few months old, Samsung,and it looks FINE, until it is powered and then you see the "spider web" pattern.
Keep this in mind in the future..flat panel sets are MUCH, MUCH easier to break than the "old fashioned" CRT Sets, that you REALLY had to try and break. A minor "tap", less than needed to break a window, is ALL that is needed to kill an LCD OR plasma set.
Our tv got hit with something and now has a spider web look in that spot and now its cracking on the inside. nothings wrong with the panel whats is the part thats broken
Unfortunately the screen has been damaged beyond repair & will need to be replaced. The cost a new screen of this size will be almost he same as buying a new TV. As it was accidental damage & if you have home contents insurence try to make a claim for the damage.
Water inside
try remove your screens and clean it
if notwork your engblock is bad
Lcd covered in water,semi circles at bottom of screen
could be pressure damage from objects at it, hard to say, usually the glass would have spider cracks around each presure spots, but LCD is soft so the pressure damage explains what happened.
If the spots are near the bottom the liquid may have crept upward from the edge , try a hair dryer on a spot and see if it changes indicating liquid is still in there.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
4helpful
2answers
Screen looks fine when off looks ''shattered'' when turned on
It would be better to buy a new one, the cost of the panel is a little bit lower than a new TV, but you have to take into consideration the tech to swaap the panel.
1helpful
2answers
Hitachi 51UWX20B spider web like lines help
I know my response is a while after you asked, but to clean the inside of the tv case is pretty simple.
Remove the bottom speaker cover...on this model you just pull it off. There is no clips or screws.
Once the speaker cover is off you will see the bottom of the screen, there is 4-5 screws on the bottom on each side....I think 4 in the gray plastic and 1 in a black metal strap. With all of those screws out pull out SLIGHTLY on the screen and push up. The top is held in with a down force clamp and you are just popping it out of that....It will pop back in once you are done.
Now clean the back side of the screen, the mirror and CAREFULLY dust off the lenses. I myself did not want to use any cleaners (to avoid streaking) so I used a new microfiber dusting cloth. My picture became brighter and the "crack" that I thought I had was just a dust web....
Hope this helps and good luck
N8
4helpful
2answers
Broken flat screen tv
If you have not yet fixed this and haven't trashed the set I may have a solution.
I have a 50HP66 that has a good screen but bad sustain boards.
I will buy the boards from you...Easy to remove. Then you can use that money to buy a new TV.
Fixing a cracked screen is not practical. IE. Replacing the whole screen.
These sets are made to be sent to the land fill when the warranty is up.
Maybe we should have our lawmakers force companies to have minimum warranties for large toxic products that end up in the trash. Then they might make them last more than a year.
1helpful
Psp screen
Uh yah, I don`t think I`ve ever heard of that.
Top Dynex Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
