When i try to start my laptop.a message says that my bootmm...something is compressed.to start up press and hold Ctrl,Atl,delete.When i do that nothing is happening
i think... you better change your hard drive and install a new os..... **** **** my loptop also .......why they will give a compress selection f there is a side effect.......****,,,, you all who make that........
Say for example you want to flip it strait PRESS CTRL+ATL+UP Arrow key Flip Right PRESS CTRL+ATL+Right Arrow key Flip Left PRESS CTRL+ATL+Left Arrow key Flip DOWN PRESS CTRL+ATL+DOWN Arrow key
was boot to the recovery cd for 7 and run the collowing commands from the command prompt. (Press key after each line)
c:
cd \windows
cd system32
compact /u c:\
compact /u c:\*.*
x:
bootrec /FixMbr
bootrec /fixboot
bootrec /rebuildbcd
with that the boot loader was flagged to no longer be compressed (Prevent re-occurance), uncompressed (Make it usable), and then rebuilt.
Good day sir/maam, the reson why it froze is caused by a bad memory module, you may need to replace it. Open up your computer and locate the memory modules, remove all memory modules and bring it to a computer vendor for testing. or if you have the cash, better buy a new one. make sure that what you install on your PC be it tested or new is good.
Delete key takes you into the BIOS Setting Setup that should be avoided if not sure of what it is all about, THOUGH it would be Ok to choose Load Default (Safe) Settings and then save and Exit (F10)? and Y or something like that.
F11 is a shortcut to a setting within BIOS Setup, it lets you choose Boot Device from List, normally you would try the Hard drive , as it is there that you want Windows to Load from unless of course you are trying to boot from a Windows CD/DVD then you would choose the CD or DVD from List....good luck
if your using outlook express or outlook 2003 then yes
click on the 1st message until it highlighted in blue hold down the shift key and goto the last message and while still holding down the **** key click the last message. this will cause them all to be highlighted in blue, now just hit the delete and they shold all be gone
