Question about Sony FD Trinitron WEGA KV-20FV300 20" TV
Sony television will not respond to remote.
The television responds sporadically to Sony remote. TV can be turned on using the power button on front of set.
Any suggestions?
Thank you,
MKelly
  • donelld Dec 26, 2008
    Does anyone know the code to program a Universal Remote?
    The codes offered in the UR packaging do not work.
    Thanks for any help
  • Anonymous Mar 18, 2014
    buttons on the side of the tv do not work are are sporadic also the remote turns on the tv but is also sporadic
  • 94 Answers
Battery in remote.
Many times I will 'reseat' the batteries in a remote & then it will work for a while again.
Posted on Jul 28, 2008
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
Tv wont respond because device menu is changing through each device
I had a similar problem: my WS-55511 would not respond to the remote and the front control buttons (with the exception of Power) cycled through the Device Menu. I solved this problem by disconnecting the front panel. Here's how to do it: 0. Unplug the TV
1. Remove the speaker grill from the front by pulling forward: there are no screws. 2. Disconnect the two cables that are exposed after the grill is removed. 3. Plug the TV back in, wait for 5 minutes to reset. 4. Try using the remote.  Hope this helps!
Oct 06, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Tv is on but wont play
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
TV Zoom mode
Change the batteries on the remote, point the remote at the Sony, and hold in the power button for 5-7 seconds. Then depress and re-press the power button - see if you can get the tv remote to respond again.
Then, always try the quick reset:
How to perform a power reset on a Sony® television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
May 16, 2008 | Sony KV-32FS13 TV
Remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-20FV300 20" TV Logo
211 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
