Question about Samsung HT-TXQ120 Home Theater System Theater System
Samsung 1310a Replacement Capacitors
I have a HT-TX75T home theater system and one of the capacitors labeled 1310a has gone bad. I would like to repair this myself but can't find the specifications on the capacitor to replace it. Any one know what the specs are?
  • 3 Answers
SOURCE: unlock home theater system samsung ht-x20
http://www.videohelp.com/dvdhacks/samsung-ht-x20/8981
This should solve it :) I had similar problems. Swapnil
Posted on Nov 04, 2008
SOURCE: v ipod mode in Samsung HT-Z420 home theater system not working
Plug a yellow video cable into the TV (IN) and the Sound system (Out) then go onto AV1 on the TV or which ever port you plugged the cable into and play a movie and u can see it. A menu doesnt come up like the A ipod funtion so it comes up no signal until u play an actual movie on the ipod. If u dont have a yellow video cable i think u can use the white or red audio ones.
Posted on Aug 20, 2009
  • 21 Answers
SOURCE: Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Posted on Sep 14, 2009
SOURCE: samsung ht-c550 dolby pro logic II mode does not work.
1. Go to the DVD input.
2. Select menu
3. Settings
4. Audio
5. ASC
6. Turn OFF the Auto Sound Calibration
7. Exit the menu
8. Go to the DVD input and retry the pro logic II button and switch to MATRIX.
(Also you have to enable the "matrix" setting each time on all of the inputs you use.)
Posted on Jan 27, 2011
When put trn on the ligth not workin only hear noise butthe ligth the buton turn on not workin
Hi, You have broken capacitor and or IC on your Home theater circuit board. Check the broken capacitor and I and replace them accordingly.
Jan 19, 2011 | Samsung HT-Z210T Theater System
Apex dt250 digital convertor-- light stays red and will not turn green and display shows--- is there a reset procedure
If you're electronics savy, as in replacing capacitors, open it up.. that's your problem.. one or two of the caps on the power board has gone bad.. most likely a 470uf 25v, which can be replaced with a 470uf 35v found at Radio shack for about $1.29. You can tell if it's bad if the top is cracked open & leaking or just domed out instead of being flat.
Jun 30, 2010 | Apex Digital HT-150 System
Hello my Samsung HT-x70 plays for about 20 minutes and then shuts off. Please help
First check in back that the fan is running. Second: Remove cover and check for bad capacitors in the back right corner. The ones in my system were blue. one had totally dissolved. I replaced the capacitor ad the system worked fine, Then found the fan was not running so replaced that too. It does take some soldering to repace the capacitor.
Jan 02, 2010 | Samsung HT-X70 Theater System
Samsung HT-X40 also shuts off after displaying Protection
You probably have the same problem that myself and several others have had, and let me guess, its outside of the warranty? How good are you with a soldering iron? If you are not afraid to do some soldering you can fix it, check out these instructions that i found:
http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
you will need 474k or .47uf 100v capacitors and a soldering iron, but you can fix it, worked for me.
Aug 08, 2009 | Samsung HT-X40 System
Protection and shut down.ht-tx35
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotation
Jun 09, 2009 | Samsung HT-X40 System
Cooling fan stopped working.
http://www.samsungparts.com/search/search.asp
try to check all the accessories for your unit here
May 30, 2009 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Tuner Hum on Sony HT-DDW740
Check electrolytic capacitor C899 100uF 35V in STBY PCB
Cheers
Dec 02, 2008 | Sony HT-DDW740 System
Sony HT-DDW740 Tuner Hum
Hi:
On the stanby power supply replace or have replaced C899 with a 100uf 35V capacitor, this capacitor goes bad and produces hum in the supply voltage to the AM FM circuits.
Rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
Nov 19, 2008 | Samsung HT-TXQ120 Home Theater System...
Samsung HT-TXQ120 Home Theater System Theater System Logo
199 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
