Question about Minolta Maxxum 400si 35mm SLR Camera
Mirror is stuck down
Mirror inside camera is in the down position and seems to be stuck....what's up with this and can it be fixed?
  • sarahbodd Jul 28, 2008
    That didn't work....it says HELP in the menu screen when in off or on position...and doesn't seem to be reponding to anything.
  • Scott Bates
    Scott Bates May 11, 2010
    is this when you put a perticular lens on it or is it stuck for all lenses?
  • 31 Answers
If it its just a perticular lens then its because the body cannot comunicate with the lens to disable the lens lock Press and hold DRIVE MODE and AV buttons while turning on camera.
Posted on Jul 28, 2008
Ty shutter mirror is stuck in the down position. How can I fix this.
Needs to be fixed by a Camera repair shop. Have to pull the mirror box, Thats what is sound like by what you are saying,
Dec 25, 2015 | Canon EOS 1100D / Rebel T3 Digital Camera
Minolta x700 cannot see through the lens. help
Which lens? Is this happening with just one lens, or with every lens you mount on the camera?
If you remove the lens and look through it, can you see light? Perhaps an upside-down view of whatever is on the other side?
If you look into the camera body after removing the lens, do you see a mirror at a 45-degree angle?
Aug 28, 2013 | Minolta X-700 35mm SLR Camera
The viewfinder screen is completely black. no image whatsoever. it seems like the camera is functioning everything works from what i gather
Since it's a film camera, there are a couple of things to check:
1. You have left the lens cap on.
2. If this is a single lens reflex camera, take the lens off and make sure that the mirror isn't stuck in the "up" position. If it is, GENTLY pull it down until it stays down. At this point, your shutter may be open. Try cocking the shutter again, fire off a test shot, and see if the mirror sticks in the up position. If it does, you probably need to replace the mirror bumper foam - age can make foam deteriorate into a gooey, tar-like substance that can make the mirror stick in the up position.
3. Does the camera have a T (for Time) setting on the shutter speed dial? If so, turn it off the Time setting and set it to a manual shutter speed such as 1/60 - or whatever your 'X' synch speed is.
4. Your batteries died in mid-exposure. Replace the batteries. You may have enough juice in them to show the viewfinder display, but not enough to finish the exposure and close the shutter.
Nov 16, 2017 | Pentax MZ-60 QD 35mm SLR Camera
Can we repair/replace the lcd of old film cameras? I have an old pentax sfx camera and its lcd does not work.
I just checked my SF-1, and the mirror will go through four cycles while trying to load the film. You should be able to hear the mirror go up and down when you open the back and close it, then turn the camera on. I cannot get my SF-1 to keep the mirror up. Check to see if you have the mode set to bulb, and that the shutter release isn't stuck down - that will keep the mirror up until you release the shutter button or turn the camera off.
Also look carefully inside the lens mount on the side nearest the red dot. at the horizontal spot there is an internal button. It should be at the bottom of the track it runs in, about 1/3 of the way from the screw below the red dot to the lens release button. That moves up when the mirror goes up, and down when it comes down. If it is in the up position, you could perhaps try to gently move it downwards. It definitely moves up and down with the mirror on my SF-1.
Jul 22, 2012 | Pentax Sfx Auto Focus Slr 35mm Film Camera...
I have an olympus om-1 and the viewfinder is black. how can i fix this? I had it in my camera bag safely and today i took it out and loaded it and the viewfinder is black.
Make sure the mirror lockup switch is not activated. Take lens off camera, look inside camera through lens mount and make sure mirror is in down position. When the morror is up, it blocks everything in viewfinder.
Oct 25, 2010 | Olympus Photography
My F75 won;t work at all
1.Most SLRs have the same problem.The paste which used to fix the reflection mirror with the metallic plate is usually rubber based, So there is a chance to the mirror to slide from its original position to down due to gravity.And particularly when you focus close ups the lens extends backward and the lens struck the mirror Positioning the mirror to its original position will solve your problem.
2.May be your camera batteries weak check it for its operating voltage.
Mar 26, 2008 | Nikon N75 35mm SLR Camera
Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Feb 04, 2008 | Photography
Mirror Locked in Up Position
When you say you put in a new roll of film, did the camera advance the film with the mirror locked up? Have you tried triggering the shutter few times to release the mirror? If that doesn't work, open the back of the camera. Turn the film take up spool in one direction...that should release the mirror down. Turn it also in the opposite direction. If that doesn't work, reach inside the lens mount opening and pull the mirror (very very gently) down. Don't force it down if it doesn't want to go. Sometimes that releases the mechanism that freezes from sitting idle for too long. It is always a good idea to take the camera out and triger few frames every couple of months to keep things lubricated. Let me know if that fixes it. AJ.
Sep 03, 2007 | Nikon N70 35mm SLR Camera
Pentax MX Mirror Stuck In Up Position
This is a result of the linkage from the shutter release button being out of adjustment. It is a mechanical fault that can be repaired very easily.
Aug 14, 2007 | Pentax MX 35mm SLR Camera
Mirror problems
Could be 1 of two things: 1. Mirror linkage failed. 2. Something is holding the mirror; sticky foam or the lubrication has dried out. Remove the lens, use slow shutter speed to release the shutter. While mirror is stuck in the up position, very gently pull down on the front edge of the mirror. If it frees up immediately it was stuck on the foam. Might be able to see a mark on edge of mirror from the foam. Hope this helps.
Apr 18, 2007 | Minolta XG-A 35mm SLR Camera
Minolta Maxxum 400si 35mm SLR Camera Logo
197 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
