Question about Kenmore Elite 45986 Front Load Washer
F32 - Kenmore Elite Front Loader Washing Machine
The F32, and sometimes the F28, codes are blinking on my new washing machine and I can't figure it out. HELP!!!!
  • 3 more comments
  • lfarrell812 Aug 02, 2008
    F32 is blinking and the door is locked and will not open. Sounds like it is running but clothes are not moving.
  • mjamsheedi Aug 07, 2008
  • threemules41 Oct 20, 2008
    machine starts to fill with water, then stops and flashes f32 code
  • little_wrigh Oct 24, 2008
    I started a load and it started to fill with water and then it stopped and f32 code showed up on the display then after a while the f28 code shows up. I am not able to figure out how to reset it so I can do a load of laundry, please help.
  • Anonymous Feb 04, 2009
    same problem, 3rd time it has happened. the washer had to be replaced the second time it happened... i think it will have to be replaced again.... hope it's under warranty.
    Problem Solver:
  • 6 Answers
These codes means that the CCU and the CMU are not talking to each other. have you moved lately or some how disrupted the connections from these modules? I don't believe your modules are bad but you'll need to have a technician check and re-secure the connections to your modules and this should solve your problem.
Posted on Jan 19, 2010
F28 error code on kenmore elite he3 washer
F28 error code is a communication problem between the CCU and the MCU. Try unplugging the machine for several minutes.
Nov 28, 2016 | Kenmore Washing Machines
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elliet washing machine, front loader
To open the door manually:
UNPLUG the machine...
Remove the toekick panel (way down at the bottom).
Feeling along the inside of the front panel. You should be able to find a tab shaped like a teardrop attached to the door latch unit.
Pull the tab down just a little bit ... gently ... until the door opens (or you hear the latch click - then try to open the door).
Is the machine displaying a code?
Apr 29, 2010 | Kenmore Elite 45986 Front Load Washer
It gives a F28 code. What is that?
F28 is a motor controller error... Try unplugging the machine for a minute or two, then starting it again. If no good, you can remove the access cover and check the connections to the motor... BE SURE TO UNPLUG FROM WALL FIRST...
Peace,
Mar 30, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Our Kenmore Elite 46752 Washing machine is displaying codes "F11"
I'm sorry to hear about your trouble and it may not be good news, I'm afraid. The F11 code is a generic code generated to indicate a communication error between the motor control board and the central control board occurred. The F28 code indicates a problem at the motor control board. The wiring connections have been known to jiggle loose and become corroded, which can trigger these codes, but if removing, cleaning, and reseating the electrical connections doesn't fix the problem you are looking at possibly replacing the control boards. Plural, because there is no real way to tell which control board is causing the problem. I would lean toward the motor control board since the F28 code was generated, but that would still be speculation. Again, sorry for your trouble and I hope this helps. Best wishes.
Aug 30, 2009 | Washing Machines
Clothes come out super wet
Drive motor failure, CCU or Motor control failure. To ceck this look at your owners manual and from then test the parts with a multi meter. To keep from spending money you can unplug your machine for 15 to 30 minutes, plug it back in and sometimes that will clear the code and everything will work just fine. Also some parts are covered under the 5 year warranty so make sure about that also
Apr 17, 2009 | Kenmore Elite 45986 Front Load Washer
HE Elite Smartwash quiet pac 4 front load washing machine
F32 is the pressure switch issue. Just press and hold the power switch for 5 seconds to reset this error.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE 3t washer
F32 is the code for a Water Level Switch Failure.
1. Remove the top panel from the washer by removing the three screws in the top back of the washer.
2. Inside the back right corner is a round plastic box, fastened to the side with a plastic snap. In will have a wire connector and a small, rubber hose connected to it.
3. Check to make sure all the connector wires are connected and tight. Unplug washer for 30 seconds to reset it. If the cycle fails still with the F32 code, you'll need to replace the Water Level Switch.
4. If the Water Level Switch does not eliminate the F32 code, it then the machine controller may have failed.
Jul 04, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
611 people viewed this question
Sal De
fordexpert
Robert Rankin
