Didn't work... still only snow
Any other ideas. I would think that this should be a simpler fix.
  • 2 more comments
  • bfmaidel Jul 28, 2008
    I had everything on, as suggested, and went through the menu options. Checked set up, checked channels. Continued getting snow. The only button that doesn't give me snow is AUX... which gives me a grey screen...but that doesn't respond to any other commands. Any channel selections return the snow.
    I have tried unplugging and replugging the tv in hope that it might reset... but did not.
    If I have misunderstood the technician, perhaps I need step by step instructions.
  • espiess4 Aug 18, 2008
    my tv worked fine with hd channel box from cox cable.after we lost power from a bad transformer and tv came back on did will not work on hd channels it only rools cox had a tech here and he said it is the hd receiver in the tv what do you suggest gary m spiess sr
  • todarrell Sep 05, 2008
    using dish network, worked fine until I unplugged everything because of a storm. Now I cannot get a picture (snow screen) dish tech tried to help but I could not get TV to channel 73 which I need to connect to dish.
  • Peter VanderStoep
    Peter VanderStoep May 11, 2010
    While installing a new dvd/vhs
    recorder-player to my Hitachi 31cx6b, I mistakenly set the new remote
    on the Hitachi remote and bumped a few buttons. I instantly lost the
    picture and have nothing but snow on all channels.
    Please advise how I regain the picture.
    Best Solution posted on Jul 27, 2008
    tx 4 trying - closed thread.
    pferd
    Rank: Wiz
    Rating: 77%, 11 votes
    It sounds as though the TV [video monitor {Hitachi}] is not set to an input that is sending a signal. Snow is the result.
    Cycle through the inputs on the set with ALL devices ready to send signal.
    If you have good access to the input area you should see all of the names and what is plugged into each.
    Tell us exactly what you did do.
Wiper not working
Sounds like you damaged the gear drive that operates the wiper arms, time for new wiper motor assembly is my guess. Don't use the wipers to brush off snow, very bad idea, the drive gears are plastic and on this old dog very brittle from age.
Sep 23, 2016 | 1993 Mercedes-Benz 220
Snow Cone Machine Won't Work
Nostalgia does not have repair parts, return the machine to where you bought it.
Mar 10, 2013 | Nostalgia Electrics Kitchen Appliances -...
My Samsung DVD Recorder rejects my blank DVD disc after having used it 2 years without any problem. What is causing this?
Hi, I think I have the answer. Try putting in a different type of disc, start with going to a simpler format of disc-if yoou were using dvd r/w +- for example then go to plain dvd r. If you were using dvd r's-then try putting in a data disc ( cd-r ) and try recording a song. I you can record in a simpler format I'd have to say that your samsung's probably reached the end of it's life cycle and is just plain getting weak. I'm sorry I didn't have better news. You may try a " LENS CLEANING " dvd also-as there have been cases of actual dirt being a culprit. I hope this was helpful, please comment though, Thanks and good luck , Prodzilla
Apr 13, 2011 | Televison & Video
I have a Montgomery Ward Snow Thrower Model 495A. A rope got caught in the auger. Now the motor runs but the auger will not turn. Any idea what was broken and where I can get parts to fix it?
I have an older Montgomery Ward Snow Thrower model No. TM0-35286A and I'm having a hard time finding parts for it. The tiller just stopped working so I'm thinking the worm-gear is shot, but I can't even find the part on-line...Can you help?
Dec 10, 2009 | Montgomery Ward (223600UP) Heater
Drove over a snow bank. mostly left side of my wrangler was on the bank, about 45 minutes later there was, i guess it could be best described as a scraping noise coming from below my front passager seat....
Jack the front end and try a twisting motion on the wheel. There should be almost no play in it at all.
Take a look at the suspension and see if there is anything noticeably different between the two sides...this will let you know if you have bent something.
Dec 01, 2009 | 2009 Jeep Wrangler
Mitsubishi WD52725 "SNOW" Screen......
try pressing menu 2470 and enter. this will reinitalize the set. if that doesn't work the there is a problem with the chassis. check out www.tv-techs.com
Dec 31, 2008 | Mitsubishi Televison & Video
Sansui Plasma, Green and Red Snow
I have the same tv - change the power supply. Corne Bronkhorst
Mar 14, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
52" SHARP LCD getting a snowy picture after 5 to 10 minutes
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.They have fixed these ynits out of warranty with a smile.This is a issue with defective parts not connections
Feb 21, 2008 | Sharp LC-52D43U 52 in. LCD HDTV
52" Sharp LCD getting snow after 10 minutes
omg i have the same problem too!!!!! I havent figured out how to fix it...have u?
Feb 21, 2008 | Digimate DGL32 32 in. LCD Television
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
