Question about Samsung DVD-V3500 DVD Player/VCR
DVD won't eject
DVD shows LOADING but nothing happens. Can't eject
I started loosing the screws and it started working after I shook it. No real technical explanation as to why it happened. Maybe a bad dvd rental?
Posted on Jul 28, 2008
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
RCA L32WD26D TV/DVD/HD Combo - dvd wont eject
Hello
Check the loading motor and loading belt. If loading motor has damaged, or loding belt has broken or loose. the in-out tray mechanism won't work well.
Mar 03, 2012 | RCA L32WD26D HDTV/DVD Combo
CD is stuck inside of a tv/dvd player
Try shutting the television off. With the unit turned off, hold the eject button and turn the unit back on. Continue holding the eject button for 30 seconds or until the DVD comes out.
If this doesn't work, try unplugging the TV for 5 minutes and attempting the above steps.
Hope this helps!
Dec 06, 2011 | Toshiba Televison & Video
PowerMac G5 doesn't eject
Your DVD wont show on the desktop unless a DVD is inserted. Which means that the DVD is either upside down, or simply isn't recognized by the reader. There should be an eject button on your keyboard. Hold that for 3 to 5 seconds and see if it ejects. If not, look for a tiny hole in the front of your case and insert a paper clip and push in until the DVD ejects. Some Macs have no hole and require a shop to extract the DVD for you. Another trick is to start up the PC while holding down the C key during bootup, which will make the PC try to boot off of the DVD. At which point the DVD should eject as the system asks for a proper boot cd.
Feb 28, 2010 | Apple iMac G5 Desktop
DVD stuck inside sony dav-sc5. Pressed the eject button and nothing happened. Did the usual turn it off and on again and it started to read the disk but then nothing happened. Tried to eject it and nothing...
Have you tried to unplug the unit for 1 or 2 minutes to see if it can reset the computer chip inside of the DVD player?
I have had great sucess with this trick.
I hope that this helps you out of this situation.
asnowman
Feb 08, 2010 | Sony DAV-SC5 System
Original xbox continous blinking green light, no eject & loading
sounds like a bad cable between the console and the TV, the XBOX is notorious for having issues if the cable isn't the correct one (a Microsoft one) or damaged.
the flash green with nothing else happening can be a failed bios.. coma console variant. It's possible to fix it with a chip, but uneconomic considering the price of a working box these days. It can also be a failed ide controller or bad ram..whatever, it's normally a scrapper with these symptoms unless you have a good junkbox...
If you have an xbox that fell it's always worth changing over the dvd drives, as they can cause weird faults as well, (as mentioned above re: unknown disks) as the green flashing is the usual "loading disk" message.
Sep 08, 2009 | Microsoft Xbox Console
Cannot eject DVD or turn off machine or anything
hold your power button down for 8 seconds and the machine will power down
Feb 19, 2009 | JVC DR-MV5S DVD Recorder/VCR
My LG dvd/vidoe machine will not eject the dvd, it says loading but does not load either
unscrew you're dvd to get the disc or go to the nearest service center.
May 13, 2008 | Televison & Video
DVD does not play just spins and keeps showing loading.
Check to see if the disk is dirty, has fingerprints or is scratched. This has happened to me in the past and if dirty, cleaning it will correct the problem.
Jan 02, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Samsung DVD-V3500 DVD Player/VCR Logo
94 people viewed this question
Henry  Thomas
Henry Thomas
