Question about Intel Motherboard
Problems with dll error
I have downloaded free regcure/ registryfix none have worked so ive deleted them. the problem is with this file MYWEBS~\bar1\binPlugin.DLL, I understand this is a screensaver dll, are you able to help me? Please.
  • 781 Answers
Does this popup as error if so go to search type in
click search if found delete it
Posted on Jul 28, 2008
I have a MSI A6000 laptop. I recently had to set it back to factory restore.Now I get the message MagCore.dll is missing from your computer.Arccon.ac-system error.How do I fix this?
I strongly advise against fixing arccon.dll errors manually. Doing so could take several hours, do more harm than good, and end up not even resolving the underlying problem.
The most recommended solution is to use a reliable software application that can quickly diagnose and fix arccon.dll errors (and much more). Programs such as RegCure Pro run a variety of troubleshooting and diagnostic tests on your computer in order to pinpoint and fix almost all known issues. The result is an error free PC that is actually much faster than before.
Download available to fix arccon.dll errors. Recommended: To repair arccon.dll errors, use this software package: RegCure Pro. This repair tool has been proven to identify and fix arccon.dll errors and other Windows problems with very high efficiency.
Download Now
File Size 5.6MB Requirements Windows XP / Vista / 7 / 8 Downloads Over 500,000 Download Time Broadband: 6 sec / Dial-Up: 3 min End User License Agreement
Uninstall Instructions
Jan 31, 2014 | Computers & Internet
Fix kernel dell xp
There are several different ways that kernel.dll errors can show up on your computer. Here are some of the more common ways that you might see kernel.dll errors:
  • "Kernel.dll Not Found"
  • "This application failed to start because kernel.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\kernel.dll"
  • "The file kernel.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: kernel.dll. Please install [APPLICATION] again."
Kernel.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the kernel.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Kernell.dll Errors
Kernel.dll errors are caused by situations that lead to the removal or corruption of the kernel DLL file.
In some cases, kernel.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Kernel.dll Errors
Important: Do not download kernel.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of kernel.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the kernel.dll error.
  1. Restore kernel.dll from the Recycle Bin. The easiest possible cause of a "missing" kernel.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted kernel.dll but you've already emptied the Recycle Bin, you may be able to recover kernel.dll with a free file recovery program.
    Important: Recovering a deleted copy of kernel.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some kernel.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the kernel.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the kernel.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the kernel.dll file. If the kernel.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the kernel.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to kernel.dll. If, for example, you're receiving a "The file kernel.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The kernel.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if kernel.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the kernel.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The kernel.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause kernel.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual kernel.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair kernel.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid kernel.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the kernel.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the kernel.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any kernel.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The kernel.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 8, Windows 7, Windows Vista, Windows XP, and Windows 2000.
Sep 12, 2013 | Microsoft Windows XP Professional for PC
How to remove from the error 5201
What Type of Printer is it? Each Company has their Own Trouble Codes...
Cannon for Example"
Problems with Error 5201
Cause: 5201 errors usually are caused by misplacement or broken system registry
structure.
Note: This is also a critical sign of an unstable system that is usually caused by improper
maintenance of the computer
Solution: RegCure is a Microsoft Certified tool that is tested to repair issues with code 5201 errors.
Download & Fix with Regcure Repair Tool Free!Windows 98/SE/ME/XP/Vista Compatible
Regcure Additional Features:
Repair ALL detected Registry Errors instantly!
Optimize PC's performance up to 300% Faster!
Prevents Freezing & Crashes - Completely!
Increase Window's Boot & Programs Speed!
Advanced Windows configuration settings!
Error Code 5201 Problems
JavaScript / Scripting Errors
Internet Explorer / Active X Errors
EXE / DLL / OCX Errors
Virtually all Windows related Errors!
How To Use:
Step 1: Download & install RegCure Repair Tool for FREE!
Step 2: Scan your computer
Step 3: Click the 'Fix Errors' button & your DONE!
Apr 12, 2013 | Office Equipment & Supplies
When trying to run the drfagment or Msconfig, I recieve messages that I am missing file MFC42u.dll
try sfc /scannow If still no go, try copying file from C:\windows\system32\dllcache to c:\windows\system32
Jan 21, 2011 | Dell Dimension 1100 PC Desktop
In my ' PhoneSuite_exe_V2[1].3.0' software 'libexpat.dll' is not found. now, how can i install this software? can u send this software to my email?
How to Fix Libexpat.dll ErrorsImportant: Do not download libexpat.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of libexpat.dll, it's best to obtain it from its original, legitimate source. Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the libexpat.dll error.
  1. Restore libexpat.dll from the Recycle Bin. The easiest possible cause of a "missing" libexpat.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted libexpat.dll but you've already emptied the Recycle Bin, you may be able to recover libexpat.dll with a free file recovery program.
    Important: Recovering a deleted copy of libexpat.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some libexpat.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the libexpat.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the libexpat.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the libexpat.dll file. If the libexpat.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the libexpat.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to libexpat.dll. If, for example, you're receiving a "The file libexpat.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The libexpat.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if libexpat.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the libexpat.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The libexpat.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause libexpat.dll errors as they fail.
  10. Repair your installation of Windows. If the individual libexpat.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair libexpat.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid libexpat.dll registry entries that might be causing the DLL error.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the libexpat.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the libexpat.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any libexpat.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 01, 2011 | Draytek High Speed Gigabit Router V2130N
When trying to scan, my scanner software program comes up with "twain_32.dll" not found. My HP PSC 1350 Printer/Scanner has always worked before.
http://www.fix-all-dll-errors.com/twain_32.dll/
Just visit this site...this will help in case of missing or downloading dll's , also if dll's are corrupted or errors in dll's..!
I also registered few dll's from this site...worked in my case. :)
Dec 24, 2010 | HP PSC 1350 All-In-One Thermal Printer
How to install msvcp90.dll
hi,
http://www.fix-all-dll-errors.com/msvcp90.dll/
u can go to this site...this will help in case of missing or for downloading dll's or also if there is errors in dll's..!
I also registered few dll's from this site...worked in my case :)
Dec 17, 2010 | Microsoft Windows XP Professional SP3 Full...
Windows XP boot after an error, it can not find the file shfolder.dll, and is included in the Windows folder. What do I do?
http://www.fix-all-dll-errors.com/shfolder.dll/
This will fix the issue without any botheration.find that dll here :)
Dec 15, 2010 | Microsoft Computers & Internet
Everytime i restart it pops up
this hibopiro.dll is a registry entry that is starting a trojan or spyware that you may have deleted from your computer at some point.
if you have regcure you can run it and see if it gets rid of the reference to the .dll file.
if you install hijackthis and run it and look for this reference.
I would be careful about using regedit unless you know how.
but you can go to the hijackthis website and have someone look at your results for free and they will tell you what to do with their findings.
If this helps you please leave a vote in fixya
May 22, 2009 | Dell Dimension 2300 PC Desktop
UNABLE TO CONNECT MY PHONE WITH THE LAPTOP
All you have is a DLL error if you go to RegistryFix.com or DLL-Doctor.com and they can fix the problem if at all you can download Active Sync 4.0 and that will update your drivers
Jan 13, 2009 | HTC P3300 Smartphone
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
