Expert
- Posted on Feb 24, 2011
Re: We have this machine that we purchased in Italy in...
Obviously you have problem with non return valves at the pump, they are built inn the pump.
- Remove the filter holder, open the steam valve and command brewing coffee. If water comes from steam valve close it> continue brewing and wait the water from coffee group. After this procedure test it with coffee.
- If testing with coffee is successful you may work with that pump but always be careful to not leave empty water container.
- If testing isn't successful you need to change the vibration pump.
