FixYa.com
Tags:
Gateway 80GB NOTEBOOK HARD DRIVE KIT FOR SOLO 9300 SERIES
Gateway P3 600 Monitor Problem after upgrade
By Horner - usenet poster
Hi All,
I recently upgraded a gateway P3 with 128 mb ram with a 80 GB hard
drive.
Now, opened the case , cleaned it out of old dust (carefully).
When I plugged in the new hard drive and re started the machine the
monitor did not turn on. In fact it fails to come out of standby mode.
So I put in the old hard drive.
same problem.
Took out the AGP card , put in a PCI one, old hard drive , same
problem.
Took out the soundcard, modem, network card, all the items, put in AGP
card, same problem.
Same problem wth PCI.
There are no strange beeps or anything else that could tell me what
the problem is. I was wondering if anyone else encountered the same
problem, a problem like it, or could give me any pointers as to what
is wrong.
BTW, the new 80GB hard drive works fine. Tried it on another computer.
Rob
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 11, 2005
Not Rated (0)
Cornish
Cornish - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
New one for me, but I'd say bug Gateway about it.  Messing with their techs
can be fun ;).  And if it's under hardware warrenty still you may get a new
monitor out of it.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Powe33
Powe33 - usenet poster
Rating: 0%, 0 votes
On 1 Apr 2003 01:34:28 -0800, ral @y2kprawn.com (Rob) wrote:
Unplug system from wall, remove memory and video card, then return
them.  Plug back into wall and try it.  If it's still not working
consult manual for the CMOS reset jumper location (use it).
This likely has nothing to do with the monitor, usually the system
isn't POSTing, initializing the video BEFORE it gets to the monitor.
The one thing that might help if it WERE the monitor, would be to also
unplug it for a moment if it's the type with a soft-on power button
(meaning a logic circuit with internals always powered even when it
appears to be "off").
Dave
__________________________
Please Reply to Newsgroup,
Solution #3
Not Rated (0)
Odud
Odud - usenet poster
Rating: 0%, 0 votes
Thanks for all the suggestions.
You will not believe what happened.
Ok, there was no post messages, and I could not get into the bios.
Took out the P3, put in a p2, nothing happpened.
Put back in P3 and booted the computer, everything was fine.
How strange is that !!!!?????????!!!!!!!!!!!
Solution #4
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
Rob,
        Make SURE your IDE cables are on correctly (not reversed), or in most
cases your computer will not boot.  In fact, you might try booting
without any IDE cables attached to drives just to establish if this is
where your problem lies.  Of course, there are other things that cause a
boot failure such as RAM failure, processor failure, or dislodged power
connector.  Start to simplify your problem and notice any audible error
codes when present, these will tell you where your problem lies.
Ken
Can you Help with these Hard Drives problems?
Hard Drives
USB Plug and Play stopped...
My Beyond Micro 250GB Mobile... Answer This...
Hard Drives
necesito driver de sonido
sony vaio instal? windows vista... Answer This...
Hard Drives
PROGRAMS TO DOWN LOAD MY FS10...
i want to find a good program... Answer This...
Hard Drives
drive not detected in Mac
I had used the Maxtor OneTouch... Answer This...
Hard Drives
My external hard Drive DIGITAL...
My computer doesn,t noticed it... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
