Question about GE Spacemaker JVM1640SJ Microwave Oven
Model Jvm1440wh01 I inadvertently put some aluminun foil in microwave, the bag caught on fire and microwave went dead. I replaced fuse but so far have not been able to get machine to operate. Thanks
  • GE Master
  • 9,098 Answers
There should be a flame sensor (aka oven thermal cutout or TCO) located on the top left side or corner of the chassis.
You will have to remove the outer cover to find it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
Heat: I placed a microwavable food product in my sharp carousel r-1505. there was a tiny piece of the foil still attached to the rim of the product container. upon start, the foil immediately caught...
Maybe. The presence of metallic material (foil, stainless steel silverware, etc.) in an operating microwave oven creates electric arcs between the foil and the inside wall of the oven. And this can destroy the electric components.
Sep 22, 2013 | Sharp R-1505 Microwave Oven
Daughter put tin foil in microwave. Now it take 5 min to pop a half a bag of popcorn. And won't make a baked potato at all.?????
any exposed metal will burn up a microwave.Unless it is a very exspensive model,It will cost more for a repairman to fix than it would to replace
Oct 11, 2010 | Maytag Microwave Ovens
A bag containing sandwiches that were wrapped in foil was put in the microwave for ten seconds to warm them. Of course no one realized that the foil was in the bag. The bag caught fire and the microwave...
The arcing that caused the fire also caused the microwave generator be over loaded and sent stray voltage into the chassis. Microwaves MUST have the proper coating in the oven or aching will occur all the time. IF the coating is damaged and it can be damaged in areas that you cannot see, you will be money and heartache ahead if you replace the whole thing now.
Feb 23, 2018 | Maytag MMV5165 Stainless Steel 1000 Watts...
Hamburger in foil wrap put in microwave - shorted unit out
Hi- The first thing here is safety. If the power supply is good- 120v at outlet- then address the fuse in the cabinet. Open door, remove screw(s) holding control panel, and tilt out panel. Fuse should be visible. Check for continuity. If bad, replace with 15amp appliance fuse. Plug in and check for operation. If fuse blows again, unplug and start looking at a new microwave. Let me know if this info helps. Have more if needed- Thanks- Ed
Mar 15, 2010 | Whirlpool MH6141XK Microwave Oven
Rudy0819: My GE Microwave Spacemaker model JVM1440WH01 just stopped heating. I used it earlier and it worked fine. When I went to use it again, it won't heat. Everthing else works, the light, fan, etc,...
The most likely thing is the magnetron has 'died' but there is a high voltage fuse between the capacitor and the magnetron which may blow. Either way, repairs to microwaves are dangerous and should only be undertaken by a qualified repairer. PS I have seen a mouse cause this problem!
Sep 22, 2009 | GE JE1640 Microwave Oven
MW8115SS worked perfectly and then went dead
Blown fuse , take the outer cover off and change the fuse. Iff you don't have a fuse use a piece of tin foil until you find a replacement fuse.
Hopefully this helps you out.
Aug 18, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
I tried poping some popcorn in a brown paper bag and it caught on fire. I tried to the microwave again after i put the fire out and cleaned the mess up but nothing is working at all. No breakers were...
all microwaves have flame sensors that will cut the power in case of fire, this sensor will most likely have to be replaced. this will require you to drop the m/w and remove the case.
Jun 16, 2009 | Maytag MMV4205 Microwave Oven
How to replace thermal fuse/flame sensor
GE JES 1358 WK 01 microwave:
I recently had the same problem with a "flame sensor, " aka "thermal switch." My microwave is a "throwaway" model, very few repair parts available. I didn't want to replace it, so I did a little bit of research into thermal switches. I actually found one that would replace it for about $5 (plus $5 shipping).
Mine uses a "bimetal" thermal switch. There are three kinds of bimetal thermal switches: automatic reset, manual reset, and "one time use." The really interesting thing is this: the "one time use" resets (!!!) if the ambient temperature is below 0 degrees C, or 32 F (freezing); or, in some cases, -31 C, or about -22 F.
I put my "dead" flame sensor in the -10 F part of the freezer for about 20 minutes...
Checked it with my multimeter, and the once-dead sensor now read continuity (zero ohms)!!!
Reinstalled it in the microwave, and now it works fine.
So if you have a dead sensor- try freezing it...
Sep 21, 2008 | Microwave Ovens
Fire from top of Microwave
It's not a dangerous or diffcult job for a do-it-yourselfer.
That would be the waveguide cover (also called the stirrer fan cover), and it would need to be replaced to prevent future damage to the magnetron.
Check your model number sticker to get the full model number with suffix and the manufacturer number (PACO1860AB0 for example).
Then you can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Good luck and good cooking!
We appreciate your thoughtful rating of our answer.
Nov 11, 2007 | Amana ACO1860 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
431 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
